SOURCE: My Nespresso citiz lungo button will only give
Ok, what you have done is programmed your machine. If you hold down the button for 3 secs you get 3 secs of coffee, so turn on your machine wait for it to warm up then without using a capsule press and hold the button until you get 110mls for a lungo and this will be stored in the memory. If this doesn't work there is a on/off switch on the right handside turn it on with your finger down on the lungo button for 5 secs and then release the button and this will take it back to factory settings.
SOURCE: Saeco Odea Giro descaling problem
Ok first check if the machine is in greenlight state when you press and hold the water button, as it will not work when the red exclamation mark blinking.
also check if the button work at all flipping back and forth to hot water and steam.
I have never had this problem that it dident work.
But remember this, you dont have to do the descaling again as that has nothing to do with the reset.
You can even reset the descaling alarm with out having done the descaling.
If that for some reason wouldent work I would think its the CPU card is not working.
SOURCE: delonghi magnifica eam 3200 won't descale
we are encountering some connection problem that's teh reason why our converastion are always in cut.
if you read this let me know here i can help you to solved your problem.
thanks,
SOURCE: Hi, I have a DeLonghi
Hi, I have the same problem so I wonder if you managed to get it fixed and how. J.
