Your unit has DC Offset(a damaged amplifier) which is why it keeps shutting down. If you are interested in repairing your Sony, please visit my website at audioserviceclinic.com. Thank you.
is the filter timer enabled. what are the total filter hours it has recorded.
is the air filter and vents clean etc.
it seems to be getting too hot as you suggest
Seems heat related so first thing to change would be the coolant sensor in the thermostat housing. This tells the ECU whether the engine is hot or cold. If faulty after 10 - 15 minutes it could over fuel and cut the engine not allowing it to start until it has cooled back down.
try this, I was researching and found that this solution worked. While all the lights are blinking, close the dishwasher door and let the machine run through the cycles. This actually happens pretty fast. Then it will stop and quiet down and all the blinking lights will shut off. Then just press the buttons you want and hit start and the machine will start. The time it takes for the blinking light to shut off is about 1 to 2 minutes. It worked for me.
Normally when this happens it is because the impedence load is too small. This unit requires 8 Ohm speakers. If you connect 4 Ohm speakers, it will work, but work harder and generate excessive heat. If the heat is too much, the unit will enter protect mode and shut down. Once it cools off, it will work again. In your case, if the speakers are the correct impedence, check for crossed wires. If that is the problem, running the unit at higher volume levels should cause it to shutdown sooner.
i had the volume of the multi-zone tuned too high and was attenuating it in an external control box. Once i took the multi-zone volume down to -25db, the problem went way. My main zone was operating around -35db so did not have the problem.
The two left quadrants of the Ring of Light flash red on the front of the Xbox 360 console
This behavior occurs when the internal temperature of the console
exceeds the acceptable limits. You may think of this as too hot,
overheating, and so on. Make sure the fans are operating and the system
has adequate ventilation.
Since you've been inside it's possible that a heatsink or some other part of the cooling system is not working properly or is loose. Check all these!
