Washing Machines Logo
Question about Estate Washing Machines
Will not rinse or spin
The washer filled with water and it washed the clothes but then stopped. It did not move to the next cycle, it did not empty the water. Also when I manually move the knob to rinse or spin it does nothing. If I move the knob to the wash cycle the spindle will move but when it usually would empty the water it stops again.
Kenneth Simmons
  • Estate Master
  • 1,238 Answers
I have had similar situation with my top load washer over the years. It has been the timer 3 times and the water pump 1 time.
How I came up with it being the timer. The knob which you set it on the type wash you want. Put it on a different cycle and see if it completes the wash cycle. example if my washer is not working when I put it on heavy wash cycle I might put it on the casual wash cycle. If you change the wash cycle and it goes through the complete cycle it is probably the timer which is part of the knob you change for different wash cycles with.
If it stops when it is time to empty the tub on all cycles it may be the water pump which empties the tub. The one time I had a problem with the water pump it was a small piece of coal had the pump locked up. I never figured how it got out of the tub and to the pump but I put it back together and it worked fine.
It should not go into the spin cycle if the tub is full of water.
Two of the timers I bought cost 40 - 60 dollars. One was 140 dollars I bought a new washer that time because the washer only cost 220 dollars.
Posted on Dec 03, 2017
5 Related Answers
ginko
Ginko
  • 19396 Answers
SOURCE: Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Posted on Nov 20, 2008
    Anonymous
    • 188 Answers
    SOURCE: Kenmore front-load washer stops at rinse cycle
    When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
    Posted on Mar 03, 2009
    Anonymous
    • 3361 Answers
    SOURCE: amana washer only works on delicate cycle
    Open the control panel. Unplug the timer and then plug it back in good and firm.
    If it does not work correctly after that,
    Replace your timer.
    Posted on Mar 12, 2009
    Anonymous
    • 686 Answers
    SOURCE: LSR9434PQ3 Washer stops in cycle
    weak capacitor. Bolts onto motor
    Posted on Apr 06, 2009
    Anonymous
    • 1056 Answers
    SOURCE: Kenmore 80's series top loader only works on wash and rinse cycle
    This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
    Posted on Jul 01, 2009
    How to just run the spin cycle?
    https://www.manualslib.com/manual/85754/Kenmore-29522.html#manual
    Kenmore 600 Series Pdf User Manuals. View online or download Kenmore 600 Series Use And Care Manual. ... Kenmore Washer Use and Care Guide.
    Probably the worst washing machine manual I have ever read!
    Try this.
    Put your wollens in the machine, set for cold water, Woollens Cycle and your 'Soak' detergent. It will agitate a bit, and as soon as it stops filling, turn it off.
    After say 20 minutes. Then Move the dial to Spin, and pull the knob out. It _should_ pump out and spin.
    1helpful
    Spinning cycle
    Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
    Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
    Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
    Maytag washer (LAT7400AAV)shuts off during rinse cycle
    The machine control board is programmed to allow a maximum continous fill time of six minutes
    or an accumulated fill time of 8 minutes for each full wash cycle.
    If the required fill time exceeds the time limit, the washer will shut down.
    This is to prevent flooding in the event there is a loose hose clamp or damaged air dome hose.
    Check the incoming water lines for a minimum pressure of 20 psi.
    If lower, the customer can use smaller clothes loads and reduce the pressure to 10 psi.
    An alternative solution would be to change the plastic inlet screens to metal screened washers
    and remove the nozzle extender found in the water valve inlet hose near the dispener inlet."
    Whirlpool washer model lsr8233eqo
    So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
    1helpful
    Hi, I have a WA75T65GW1 7.5kg top load washer. I run a favourites program with cold water cycle, auto level and fast spin. The cycle is getting stuck all the time between rinse and spin cycle, bowl is...
    This problem will often occur with a light load of clothes. The beeping is usually the unbalanced load alarm. Often, redistributing the clothes around the agitator and moving the agitator manually up and down and side to side to center it again will fix the problem. You may need to advance a new cycle to where it spins out to empty the washer and run the laundry again.
    1helpful
    Moffatt washer is washing and draining but not spinning out the clothes
    All content © 2000 © 2009 Washerhelp
    > Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
    Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
    Does washer drain before the spin cycle starts?
    Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
    5helpful
    2answers
    Washer will fill fill with water but doesn't start wash cycle
    it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
    33helpful
    2answers
    Bosch classixx 1000 washing machine - stops on spin
    Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
    1helpful
    70 series Kenmore washer
    POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
    IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
    Top Estate Washing Machines Experts
    Marvin
    Marvin
    Mike
    Kolbrun...
    Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
