Question about Frigidaire FFLE1011MW Electric Washer/Dryer Laundry Center - White
Frigiadaire stackable dryer beeps 3 times then shuts off
1 Related Answer
chrispolkele
Electrolux
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: dryer turns on then shuts off
    Hello - The following could be reasons for your dryer to stop working; there could possibly be a malfunction in the thermostat in the return, so if it gets too hot on the auto dry cycle, it stops and will not re-start until it cools down. This could be caused by either lint or something else clogging the vent thus causing it to overheat. You should be able to feel the top of the dryer right at the back of the top near the console right after it shuts off. If it is getting too hot to the touch look to the items I have mentioned. Should you find that these suggestions are ineffective, may we suggest contacting a professional to move forward accurately who will be able to diagnose the problem.
    Posted on Oct 26, 2012
    1helpful
    Fridigdere up rite stackable dryer keeps beeping and shuts off after running for about 5,10 seconds,what do I check,?????
    Google the model and codes. You should find instructions in how to to retrieve the codes and that will point you in the right direction.
    Oct 14, 2016 • Dryers
    2answers
    Dryer shuts off after 5 seconds then beeps 3 times
    Check the thermal cut off, the cycling and the hi limit thermostats.
    For continuity or OHMS. If no ohms or resistance they need replacement.
    Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
    Test with a meter at room temperature and it should show continuity.
    A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
    My Frigidaire stackable laundry center will not fill with water?
    Hi Keith Knapp, I appreciate your inquiry!
    I understand that your Frigidaire laundry center is not filling with water. It sounds like you could be having a problem within water valve, control board, or door switch. I would recommend having a technician out to your home to properly diagnose and repair your appliance. Hopefully this is helpful. -Matt
    2answers
    Ge stackable washer dryer MODEL wsm2700wbwww
    3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
    Stackable dryer makes thumping noises -think its a broken belt
    9 out of 10 times this is due to a bad roller. This is not something you can do yourself. A stack model is just too complicated.
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Spin cycle lasts indefinately
    the spin cylce in washer, did not shut off?soundslike an issue with the timer itself, no servicing htetimer strictly replace, as far as teh time in the dryer, i would check for clogged/kinked dryer vent, biggest issue with any dryer, innadequate vent
    2answers
    Neptune stackable washer...
    You put the detergent directly on top of the clothes.
    Kenmore stackable unit
    Yes, you can use any safety 4-prong as long as it is a dryer cord rated at 220V.
    Frigidaire FFLE1011MW Electric Washer/Dryer Laundry Center - White Logo
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Michael Thomas
    Michael Thomas
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
