Medion GoPal PNA220XL Portable GPS Receiver Logo
A
Anonymous Posted on Jan 11, 2014
Mnavdce exe - Medion GoPal PNA220XL Portable GPS Receiver
1helpful
1helpful
Spcmd.sys
The file "spcmd.sys" is known to be created under the following filenames: %System%\cc.sys %System%\dboy1.sys %System%\g3i2ll.sys %System%\setuplk.exe %System%\setuplk.sys %System%\spcmd.sys %System%\tencent.sys %System%\zzjkxs.sys %Temp%\xpanxionvirus\a1.exe %Temp%\xpanxionvirus\a2.exe %Temp%\xpanxionvirus\tmd.exe %Temp%\xpanxionvirus\tmd1.exe %Temp%\xpanxionvirus\tmd2.exe %Temp%\xpanxionvirus3\boot.exe %Temp%\xpanxionvirus3\cc.exe %Temp%\xpanxionvirus3\s.exe %Temp%\xpanxionvirus3\sc.exe %Temp%\xpanxionvirus3\se.exe %Windir%\a1.exe %Windir%\a2.exe %Windir%\s.exe %Windir%\se.exe %Windir%\tmd.exe %Windir%\tmd1.exe %Windir%\tmd2.exe c:\boot.exe c:\cc.exe c:\sc.exe Go to this link for more info http://www.threatexpert.com/files/spcmd.sys.html it is said to be of no threat.
Your timely rating of this soloution is much appreciated.
Thanks
Mnavdce.exe has performed an illegal operation
completely uninstall programme, reboot machine, reinstall product.
Check website of programme to see if there is an update or patch to help you.
AndystUK
Aug 31, 2009 • GPS
1helpful
3answers
Be.tmp.exe application error. the instruction at "0x0040c173" referenced memory at "0x0040c173". the memory could not be read
This should all be done in safe mode and with system restore turned off for now.
This is a virus and You need to run your antivirus scan and remove what it finds,Run a cleaner program such as Ccleaner
Hit Ctrl+Alt+Delete and open the task manager,Under the process tab find and end task on tmp.exe and/or BE.tmp.exe.
It is a process belonging to an advertising program by 123bar. This process monitors your browsing habits and distributes the data back to the author's servers for analysis. This also prompts advertising popups. This process is a security risk and should be removed from your system.
%FontsDir%\nwlnkfwd.exe %FontsDir%\nwlnkipx.exe %FontsDir%\nwlnknb.exe %FontsDir%\nwlnkspx.exe %FontsDir%\nwrdr.exe %FontsDir%\oprghdlr.exe %FontsDir%\p3.exe %ProgramFiles%\internet explorer\keymaker.exe %ProgramFiles%\outlook express\keymaker.exe %System%\1025\zipfldr.exe %System%\1028\zipfldr.exe %System%\1028myztx.exe %System%\1031\zipfldr.exe %System%\1033\zipfldr.exe %System%\1037\zipfldr.exe %System%\1041\zipfldr.exe %System%\1042\zipfldr.exe %System%\1054\zipfldr.exe %System%\2052\zipfldr.exe %System%\3076\zipfldr.exe %System%\3com_dmi\edb.exe %System%\3com_dmi\edb0000a.exe %System%\3com_dmi\edb0000b.exe %System%\3com_dmi\edb0000c.exe %System%\3com_dmi\edb0000d.exe %System%\3com_dmi\edb0000e.exe %System%\3com_dmi\zipfldr.exe %System%\catroot\zipfldr.exe %System%\catroot2\{127d0a1d-4ef2-11d1-8608-00c04fc295ee}\tmp.exe %System%\catroot2\{f750e6c3-38ee-11d1-85e5-00c04fc295ee}\tmp.exe %System%\catroot2\tmp.exe %System%\catroot2\zipfldr.exe %System%\com\zipfldr.exe %System%\dhcp\zipfldr.exe %System%\directx\zipfldr.exe %System%\dllcache\zipfldr.exe %System%\drivers\disdn\ws2ifsl.exe %System%\drivers\etc\atmlane.com %System%\drivers\etc\atmuni.com %System%\drivers\etc\audstub.com %System%\drivers\etc\battc.com %System%\drivers\etc\beep.com %System%\drivers\etc\bridge.com %System%\drivers\etc\cbidf2k.com %System%\drivers\etc\ws2ifsl.exe %System%\drivers\ws2ifsl.exe %System%\drivers\zipfldr.exe %System%\export\zipfldr.exe %System%\grouppolicy\adm\gpt.exe %System%\grouppolicy\gpt.exe %System%\grouppolicy\machine\gpt.exe %System%\grouppolicy\user\gpt.exe %System%\grouppolicy\zipfldr.exe %System%\ias\zipfldr.exe %System%\icsxml\zipfldr.exe %System%\ime\zipfldr.exe %System%\inetsrv\zipfldr.exe %System%\keymaker.exe %System%\macromed\comadmin.exe %System%\macromed\comempty.exe %System%\macromed\comexp.exe %System%\macromed\edb00017.exe %System%\macromed\res1.exe %System%\macromed\res2.exe %System%\macromed\tmp.exe %System%\macromed\zipfldr.exe %System%\microsoft\zipfldr.exe %System%\msdtc\msdtc.exe %System%\msdtc\trace\msdtc.exe %System%\msdtc\zipfldr.exe %System%\mui\0418\ftdisk.exe %System%\mui\0418\gm.exe %System%\mui\0418\gmreadme.exe %System%\mui\0418\hgfs.exe %System%\mui\0418\http.exe %System%\mui\0418\i8042prt.exe %System%\mui\0418\imapi.exe %System%\schost.exe %System%\services32.exe %System%\spool\drivers\w32x86\3\mouclass.sys %System%\spool\drivers\w32x86\3\mountmgr.sys %System%\spool\drivers\w32x86\3\mqac.sys %System%\spool\drivers\w32x86\3\mrxdav.sys %System%\spool\drivers\w32x86\3\mrxsmb.sys %System%\spool\drivers\w32x86\3\msfs.sys %System%\spool\drivers\w32x86\3\msgpc.sys %System%\syskey_dll\sysupdate.exe %System%\system\system.exe %System%\tmp.exe %Temp%\5.exe %Temp%\70554keygen1.exe %Temp%\guqf296\keymaker.exe %Temp%\ixp000.tmp\efubtgis.exe %Temp%\ixp000.tmp\key_gen.exe %Temp%\ixp000.tmp\keygen.exe %Temp%\ixp000.tmp\keymaker.exe %Temp%\ixp000.tmp\tmp.exe %Temp%\ixp000.tmp\tvonuaek.exe %Temp%\ixp000.tmp\zwwltphz.exe %Temp%\ixp001.tmp\keymaker.exe
You should also download and run Spybot search and destroy and delete what it finds.
If
Fatal application error, program;mnavdce.exe,address;000A8444 unit will not activate navi
hard reset the device, turn it off on reset button/ power on/off...then wait for a minute before you switch it on...bingo! or else reinstall the software of your device..or else hardware issue (but this is more software issue).
Apr 17, 2009 • GPS
2helpful
Fatal Application Error/Pioneer AVIC-S1
my sun format my avic-s1 and i did't know what can i do ? any one can help me with this assu
Mar 20, 2009 • GPS
2helpful
Fatal application error mnavdce.exe
fatale fout toepassing op de scherm
Sep 26, 2008 • GPS
1helpful
Windows Freezing
Boot the system in safe mode
1.) restart the system
2.) pump the F8 Key until a screen comes up with different options
3.) select safe mode,
Try right clicking there and see what happens,, I,m guessing here this is a result of damages done by a previoulsy removed virus (GUESSING) it is possible that the same one could have been shard by all 3,,
I'd advise you'd uninstall norton and use the new avg free
www.free.grisoft.com
Let me know what hgappens and we can tgake this a bit further
Top Medion GPS Experts
k24674
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Medion GPS Expert? Answer questions, earn points and help others
