Question about LG Studioworks 563N 15" CRT Monitor
LG 15'' INCH FST MONITOR Model No 500G - LG Studioworks 563N 15" CRT Monitor
5 Related Answers
Anonymous
  • 180 Answers
SOURCE: lg 500g crt monitor problem
Try checking B+ coil , may be the coil have shorted .
Happy trying
Posted on Apr 10, 2008
Anonymous
  • 62 Answers
SOURCE: not set h size in dos mode
change the monitor frequency 60 Hz.
Posted on Nov 22, 2008
Anonymous
SOURCE: LG Studioworks model (500G)CRT Monitor flickers most of the time
lg 500g studioworks green color
Posted on Sep 03, 2009
Azum Saeed
  • 400 Answers
SOURCE: lg 500g monitor blinking in bi-color, no display when powered up
Sir,
there could be two possibilties for that
1 That your serial cable is not working or have broken pin .
2 Another is that you monitors picture tube has got damaged or burnt.
Usually it is second reason it can be repaired but is more expencive so i would prefer buying new one.
Posted on Nov 08, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: my monitor lg 500g model is dead
You need nto open it up and inspect it, here is the service manual; http://online.manualspace.com/computer-monitors-free-ebooks/lg-monitor-service-manual/4721/lg-studioworks-500e-500g-500n-color-monitor-service-manual-314.html
Posted on Mar 14, 2010
LG STUDIOWORKS 500G monitor dead ?
your irf 630 is not original purchase it from proper LG authorised service centre it is costly but never become faulty again duplicate mosfet overheats if your green led is on then measure voltage at E.H.T.connect meter at output transister if E.H.T. is producing then meter should show 1 digit if not then 50v will show take care that signal cable should be disconnected if E.H.T. is not producing then check +vcc at horizontal ic it should be 12v. if 12v is not present then check regulator ic 7812 insmps
Mar 14, 2010 | LG 500LC Monitor
Lg 500g monitor blinking in bi-color, no display when powered up
Sir,
Nov 08, 2009 | LG Studioworks 563N 15" CRT Monitor
Cut off screen
Replace 101 and 104 pf on Main chasis of your monitor :
Darshan
Dec 26, 2008 | LG Studioworks 552V 15" CRT Monitor
I am unable to make resolution 1024 x 768 in lg model 500G
If the monitor is somewhat old and the monitor hardware doesn't support 1024x768 resolution, installing a new driver won't help. You will have to switch to a better monitor.
Dec 21, 2008 | LG Studioworks 563N 15" CRT Monitor
Width problem
500G CRT LG MONITOR WIDTH PROBLEM
Oct 10, 2008 | LG Studioworks 563N 15" CRT Monitor
Whenever system restart , led blinking, no display
15" Monitor warranty period 1 year from mfd date.
17" Monitor warranty period 3years from mfd date.
Aug 22, 2008 | LG Studioworks 45 14" CRT Monitor
Not set h size in dos mode
Jun 04, 2008 | LG Studioworks 563N 15" CRT Monitor
Noisy sound from monitor
Go through your menu settings on the front of your monitor and see if your able to change your display timings. Also go in to your display settings and change the hrs.
Feb 18, 2008 | Computers & Internet
LG Studioworks 563N 15" CRT Monitor Logo
Top LG Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
