Question about Audiovox DPF700 Digital Picture Frame
Pictures not showing.
When i insert a USB, the slide show will start only a black screen is the only thing that shows up, followed by the device freezing and the buttons become unresponsive. About 10 seconds later the DPF restarts and tries again. How can i get the frame to display pictures?
Posted by Lunar Ahon on
Jerome Minks
  • 3,103 Answers
Make sure the cards' slide button is in the unlock position..then check to see which size cards the frame can work with..mb sizes like 2/4/6/8/12 etc..
Posted on Jan 11, 2014
Testimonial: "I don't understand what you mean by card slide button..."
I have a Kodak M850 Easy Share hooked up to my television with an mini HDMI cable. The picture shows nicely but I don't know what camera button to use to make a slide show appear on the tv. Can you help?
Starting the slide show
  1. Press the Review button, then press the Menu button.
  2. Move autourg00422004id1197998.jpg to highlight Slide Show [img data-src="http://resources.kodak.com/support/jpg/en/manuals/GLB_en_urg_00422_images/autourg00422004ID1198002.jpg" alt="">, then press the OK button.
  3. Move autourg00422004id1198023.jpg to highlight your option, then press the OK button.
Mar 18, 2014 | Kodak Cameras
How do you set the background on a Dell to show a slideshow of all of the pictures?
To use your own pictures
1.
Find the pictures that you want to include in your slide show. All of the pictures must be located in the same folder.
Open Desktop Background by clicking the Start button Picture of the Start button and clicking Control Panel. In the search box, type desktop background, and then click Change desktop background.
2.
If the pictures that you want to use aren't in the list of desktop background pictures, click the Picture location list to view other categories, or click Browse to search your computer for the folder where the pictures are located.
Picture of the Picture location menuLook for pictures in other locations on your computer.
3.
Select the check box for each picture that you want to include in your slide show.
By default, all of the pictures in a folder are selected and will be part of the slide show. If you don't want all of the pictures in the folder to be included, do one of the following:
Clear the check box for each picture that you want to remove from the slide show.
Picture of one check box cleared in a group of selected photosClear the check box to remove a picture from the slide show.
Press the Ctrl key, and then click each picture that you want to remove. Only the selected pictures will appear in the slide show.
To create a slide show of pictures on the desktop, you must select more than one picture. If only one picture is selected, the slide show ends and the selected picture becomes the desktop background.
If all of the pictures in the folder are selected, any new pictures that you add to the folder will be added to the slide show automatically.
4.
Do one or more of the following:
Click an item in the Picture position list to crop the pictures to fill the screen, fit the pictures to the screen, stretch the pictures to fit the screen, tile the pictures, or center the pictures on the screen.
Click an item in the Change picture every list to choose how quickly the slide show changes pictures.
Select the Shuffle check box to have the pictures appear in a random order.
5.
Click Save changes.
To use pictures that Windows provides as part of a theme
1.
Open Personalization by clicking the Start button Picture of the Start button, and then clicking Control Panel. In the search box, type personalization, and then click Personalization.
2.
Under Aero Themes, click a theme to apply it to the desktop. With the exception of the Windows 7 theme, all of the Aero themes include a desktop background slide show.
3.
To change the theme's default slide show pictures or settings, click Desktop Background.
4.
By default, all of the pictures associated with a theme are selected and will be part of the slide show. To add pictures from other themes to your slide show, do one of the following:
Point to each picture that you want to add to the slide show, and then select its check box.
Picture of one check box cleared in a group of selected photosPoint to a picture, and then select its check box to add it to the slide show.
Press and hold the Ctrl key, and then click each of the pictures that you want to add. Only the selected pictures will appear in the slide show.
5.
To change the slide show's settings, do one or more of the following:
6.
Click Save changes.
Your slide show will be part of the unsaved theme that appears under My Themes.
For information about customizing and saving themes, see Create a theme.
You can find more themes to add to your collection in the Personalization Gallery on the Windows website.
For information about customizing a desktop background slide show, see Make changes to your desktop background slide show.
Aug 04, 2011 | Computers & Internet
How to make a slide show on youtube?
Kindly visit the link below for a visual, step by step (easy to follow) instructions on how to make a slide show with pictures and background music, and upload it on youtube.
http://www.lostintechnology.com/software/how-to-create-a-slideshow-using-google-picasa
For you to complete these more easily and effortlessly, I would recommend to sort all the pictures that you want to include in the slide show and to choose the appropriate background music before you even start creating your slide show.
Enjoy, and Thanks for using FixYa.
Feb 19, 2011 | Computers & Internet
I do not have much knowledge about computers but I have inserted my sd card into my computer and immediately a screen came up,gave me prompts and i followed them and i was able to upload my pictures from...
When you insert SD card it should show up as a drive on your My Computer screen.
Select My Computer from the Start in windows and check. If it is not showing up then it may not be of the correct format for the PC to read. If it showing as a drive then simply click on the drive letter and you will see all the files there.
Feb 13, 2011 | Computers & Internet
I want to dowload some picture from usb on the picture frame
you probably have 2 possibilities..
1st ) is to insert the stick ..(card with the picture on ...and choose to play the slide show from it )
2nd) is to connect it to the computer ...and after that the computer will recognize it ..and you will find it in my computer folder by its name or as a removable device (this mostly in case it has a card attached)
Open the folder and inside you will be able to see the pictures that are already there ...top Load pictures just drag and drop pictures in this folder or copy and paste them..after that you will be able to see them on the frame ...make some slide shows with different folders ..or just play all..and it will change them on a preset time ..
Same thing for Mac..bu the frame will be visible on desktop..and same just copy pictures into it(be sure you do not cut them cause you will loose from computer this way ..so ..just copy ..and paste into the frame's folder
May 31, 2010 | Kodak EasyShare SV811 (8858946) Digital...
I have pictures on the card that show up on my
Keep the memory card in your camera....plug your camera into the computer and then turn your camera on...options should start to appear on the screen...follow the questions to get your solution...
Nov 08, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Can't find hidden media folders
Follow these steps to hide or show pictures on the BlackBerry smartphone:
  1. On the Home screen of the BlackBerry smartphone, click Media.
  2. Go to Pictures.
  3. Open the picture that you want to hide.
  4. Press the Menu key and click Properties.
  5. Select the Hidden check box and click Close.
Follow these steps to show a picture on the BlackBerry smartphone:
  1. Click Media.
  2. Press the Menu key and click Explore.
If the picture is in Device Memory,
  1. Click Device Memory.
  2. Press the Menu key and click Show Hidden.
If the picture is in Media Card,
  1. Click Media Card.
  2. Click BlackBerry.
  3. Press the Menu key and click Show hidden.
Additional Information If the computer is set to Show all hidden files and folders, the BlackBerry smartphone user should be able to view all hidden pictures by using Roxio® Media Manager. However, pictures cannot be hidden or shown using Roxio Media Manager. If a picture is on a media card and the computer is set to Show all files and folders, pictures can be viewed, hidden and shown by using the removable disk drive.
Sep 12, 2009 | RIM BlackBerry Pearl 8100
Only some of my pictures show on my 8'' Innova Digital Photo Fram
http://www.recuva.com/download
free program. works great. install and run on card. good luck.
May 25, 2009 | Computers & Internet
How do I put pictures in the key chain slide show thing?
Make sure the camera is on when you insert it via usb, check in the camera setup that it is set for PC USB.
Did the camera come with any drivers?
It is possible that the camera needs additional driver in order for it to operate correctly on the PC.
What operating system are you using?
More detail would be helpful, but what does it say on the screen when you plug the camera in?
Does it install it correctly or does it say there is a problem?
If it loads correctly the a new drive should appear in 'My computer'
Come back with more detail, I might be able to help more
cheers
Bri
Feb 04, 2009 | VistaQuest VQ-5115 Digital Camera
Audiovox DPF700 Digital Picture Frame Logo
201 people viewed this question
Top Audiovox Photography Experts
Marvin
Marvin
Tony Parsons
Tony Parsons
Are you an Audiovox Photography Expert? Answer questions, earn points and help others
