Is it possible to remove the glass front panel on my Kenmore stove, model #95002102, in order to clean off the ugly stains on the inside of the glass???
IF ITS A CABLE OPERATED SYSTEM AN IDEA TO CHECK THAT THE CABLE ENDS ARE NOT FREELY MOVING IN THERE HOUSING THE METAL BITS COME OFF THE CABLE EXPOSING THE INNER CORD WIRE IF THEY ARE THE CABLE IS NO GOOD AND WILL NEED REPLACING THE METAL BIT THAT GRIPS THE CABLE IS NOT LOSE ALLOWING THE OUTER HOUSING RUBBER TO SLIP AND SLIDE IF SO A JUST UNTILL IN CORECT OPOSIITION AND TIGHTEN DOWN THE HOLDING SCREW CHECK ALSO THAT THE CABLE HAS TOO MUCH SLACK TO OPERATE THE DECLUTCHING SYSTEM AND OR THE CABLE HAS NOT COME OFF THE MECHANISUM COMPLEATLY OR BROKEN ENTIERLY IF ELETERIC ACTICATED CLUTCH DECLUTCH PTO SYSTEM YOUL NEED A LAWM MOWER ELETRICTION TO DIAGNOSE THE FAULT AND GIVE REQUIRED REMEDY TO FIX PROBLEM
Electrical did shown one going to the switch but they have used it in place of the red one.
Here a link to at least circuit to help you troubleshoot where it does go. CRAFTSMAN 917 273621 Owner Manual Page 31
You can also download the owners manual here to.
It will show you the belt routing for your deck and the belt routing for your transmission. Please read the section on replacing the belts. You can print out a copy for your files. I'll be glad to explain more. Just let me know.
