Question about Samsung PN Televison & Video
Samsung tv clicking - PN Samsung Televison & Video
I've replaced every board on the samsung plasma and still clicks
What do you mean by clicks? Plasma televisions are hot cathode ray, there is thermal expansion that takes place due to heat.
Nov 04, 2016 | Samsung Televison & Video
Tv turns on for 10 seconds and then turns off. Then a red flashing blinks 6 times and repeats
Search Results
    Samsung TV On/Off Issue - Repair - Instructables
    www.instructables.com/id/Samsung-TV-OnOff-Issue-Repair/
    InstructablesThe result of this issue is a TV that will cycle between on and off repeatedly and/or an annoying clicking noise while turning on. Time to get informed about the ...
    Easy fix for new Samsung TV switching on and off power ...
    ? 4:41
    https://www.youtube.com/watch?v=H0cG3lzjuw8
    Sep 15, 2012 - Uploaded by alwaysafix
    www.alwaysafix.com Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http ...
    Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
    www.cnet.com > Forums > Samsung
    CNETAbout 3-4 months ago, my TV would start turning off and on a few times at startup but eventually would stay on after a couple of minutes. Every once in a...
    Samsung TV turning off [Solved] - Samsung - Displays - Tom
Jan 19, 2016 | Televison & Video
My samsung tv is making clicking noises and won't turn on
Clicking noises may mean a power supply voltage is not staying correct or that board is bad---a suggestion: visit shopjimmy.com who has by model number a list of all the boards used in almost every Samsung Flat screen set made.
Jun 17, 2012 | Samsung Televison & Video
Samsung LN52A550 "no picture
do you hear any click click sounds? A common theme with Samsung. My tv did click and it was the capacitors.
http://www.youtube.com/watch?v=tK7zFBBU6p4&feature=related I watched a few of these and was able to see my tv had 4 bad capacitors, de-soldered and replaced them for under $5.00.
Sep 27, 2010 | Samsung LN52A550 LCD TV
Makes clicking sound without switching on
is this a samsung? if so call them. its a well known fault on samsung lcd tv's. 0330 7267864 they should fix it for free. just explain your tv just clicks away when you switch it on.
Jul 31, 2010 | Samsung LA40R81BDX 40 in. LCD TV
Samsung tv model no LE40R74BDXIXEU TV IS USUALLY
First the main bd controls the "Turn on" sequences". When you press the Power on button the Main bd sends a "Turn on" signal to the Power supply. The clicking you hear is the Power on relay ativating. If the tv does not turn on and the relay keeps clicking then you might have a bad Main bd or there is s shorted board somewhere else in the set. The Power supply can also be bad. Have a trained Samsung tech troubleshoot the set.
Jul 12, 2009 | Samsung Televison & Video
Samsung PS42Q97HD TV clicking
Its a capacitor on the back of the tv, apparently they dry out and can explode. Our clicked for about a week before breaking, so i'd get it checked out before it breaks. Ours is being replaced under warranty.
Apr 12, 2009 | Samsung Cell Phones
Televison & Video Logo
70 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
