Question about Rheem Heating & Cooling
Furnace start stop cycle
Furnace turns and runs for a few min and stops and start again never gets to temp set on thermostat
Posted by Thomas on
millaround
    Habit-Forming:
  • 28 Answers
On properly sized furnaces there are a few controls to look at. Check the settings of the fan switch. If these are unchanged then there may be a reason the furnace is shutting off due to poor air flow and resulting high temperature. Check filter and verify air flow is good. It may be possible that a safety switch is failing and intermittently on and off. Are all the covers securely in place and hitting any safety switches? If not seated properly the cover may loosen when the fan runs and the switch shut off the unit. There is often a flame roll out switch that could have been strained. Lastly, has the thermostat been working long? Thermostats have internal heaters to stop the furnace which is called a heating anticipator. If the thermostat is near a heat source (heat duct, refrigerator, oven, person, hot water pipe), worn out, anticipator is set wrong (older electric thermostats have adjustable settings) or covered (yes, I have seen some covered) then the free room air cannot measure correctly and the thermostat cannot control what it cannot accurately measure. Of all these possibilities I would start with the thermostat and proper furnace air flow, second check the fan/high limit switch and third go component by component through the wiring diagram looking for defects in each component. If available follow the manufacturer's troubleshooting guide.
Posted on Jan 12, 2014
Why does my Coleman furnace model# DGAA090BDTA stop and start to get up to temp?
That's how it should work .Your furnace will cycle on and off to reach set point .
You don't have to troubleshoot the thermostat. The reason why your furnace cycle is once the heat exchanger get to a certain temperature the board will shut it off, fan would still work to cool heat exchanger down then once cool down furnace will fire up again .
Feb 11, 2018 | Coleman Heating & Cooling
My furnace runs to operating temp on thermostat shuts down then within 30 seconds try's to cycle back on three to four times. What would cause this.
Some thermostats have a swing setting that can be adjusted. A swing is the setting when you want the furnace to stop or start from the desired set point. For example, you set your thermostat at 70 and the swing is set at 10 degrees. Then the furnace will turn on 5 degrees below 70 and shut off 5 degrees above 70. Check you thermostats manual if it has this option.
Mar 15, 2016 | Heating & Cooling
WHAT SHOULD THE heat anticipator BE SET AT ON A MODEL COAT066BDA COLEMAN EVCON FURNACE
The typical starting point for heat anticipation is .4 amp. If you do not have a clamp-on ammeter, adjust it to .45 and observe operation for a few days. If not quite right and still short cycling slip it to .5. Then keep doing this until you are satisfied cycle time is correct.
If you have an amprobe or can borrow one, remove the stat and take a single loooooong thermostat wire. Attach it to the R or Rh and wrap it around the clamp on ammeter ten times then attach the other end to the W terminal. The furnace will initiate the heat cycle at that point. Observe the amp reading on the amprobe when full heat is on, DIVIDE that reading by ten (for the wraps of wire) and adjust the heat anticipator to THAT setting.
Feb 05, 2015 | Coleman Heating & Cooling
Coleman dgaa077bdta furnace.
Check the flame sensor is clean and connections are tight
Jun 18, 2017 | Heating & Cooling
Starting this afternoon: Thermastat was set (Manual) to turn on at 68, display window showed 63 but the furnace was not running. I manually set the turn on temp below 63, then up to 67 and the systrm...
Definitely a thermostat.It has 2 sections.One is a temperature reference section(what temp you want).The other is the temp reading section.If either one is bad,it will do just like you said.Sounds like the reference section is probably bad because it comes on for a couple minutes then shuts down.Since it was fine earlier in the day,I doubt there is anything wrong with the furnace because as you can see,it is temperature related.A furnace problem would be more of no operation at all,even if just dirty or whatever.The thermostat also would be a more common 'fail component' than the board.A suggestion also,both for a car and a house.During the summer,run the heat for 2-3 minutes,just to cycle it occasionally.In winter,run the A/C for 2-3 minutes.Do both perhaps once or twice a month.It helps keep the components,somewhat fresh I guess you would say,because cycling it occasionally helps to keep it going good.Also,if you encounter a problem,you may be able to get it fixed before you really need it.In the meantime,feel free to come on down to FL until it's fixed,we have room,lol.Although it's chilly now,the weekend will be 70's.(sorry)Good luck,Greg
Dec 08, 2010 | Coleman Heating & Cooling
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
Furnace not cycling properly
sounds like the flame sensor needs to be replace. You can try cleaning it with steel wool. This will get you by for a little while.
Jan 17, 2009 | Honeywell Electronic Programmable...
Thermostat seems to be working, furnace does not always turn on
Joss sounds like the anticipator setting on thermostat i would replace it with a digital it will be more actturat . The furnace has to go over temp setting to turn off
Jan 15, 2009 | Honeywell Electronic Programmable...
Carrier XHD183D Through-the-Wall Heater/AC runs constantly
YOU COULD EITHER HAVE A THERMOSTAT PROBLEM OR FAN CONTROL PROBLEM.TURN THE POWER OFF AT THE FURNACE AND TAKE THE THERMOSTAT OFF THE WALL.MAKE SURE YOU MARK THE WIRES SO YOU KNOW HOW TO HOOK IT BACK UP AGAIN.RESTORE POWER TO THE FURNACE.TOUCH THE WIRES THAT WERE HOOKED TO THE R & G TERMINALS ON THE T-STAT TOGETHER AND HOLD THEM THERE.OBSERVE THE OPERATION. WHEN YOU TAKE THEM APART DOES THE BLOWER STOP?TRY IT A FEW TIMES. IF IT CONTINUES TO START AND STOP YOU GOT A BAD T-STAT.JEFF
Dec 13, 2007 | Carrier XHD183D Air Conditioner
Heating & Cooling Logo
189 people viewed this question
Top Rheem Heating & Cooling Experts
Lawrence Oravetz
ray gallant
Marat Brikov
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
