The camera turns on and will stay on and the battery shows its at 100%, but the screen shows an hour glass flipping and as soon as the green and red light start blinking it stops rotating and buttons do not do anything when pushed. its acts as if I am locked out. please help
Some need the date and time set proir to using..may need to take battery off entirely and reinsert.. see if its in the menu somewhere..
Testimonial: "thanks but didn't work I only have an external battery charger so I have taken out numerous times and the "menu" button doesn't do anything...any other suggestions...thanks again"
SOURCE: free driver for gz-hd3u jvc camcorder
Hello
I've set that problem :
1/ Intall the JVC driver
2/ Import (not Capture) from JVC camera to G5 via the USB cable, you will have ".TOD" clips
3/ Convert ".TOD" to "Quick Time" with "Streamclip" software (free)
And you can edit with FCP
Best regards
Cooki
SOURCE: Dropped my jvc everio GZ-mg630
May you will need to relace the optical block assy or ccd base assy
SOURCE: My JVC everio GZ-MS120SAA is broken. When i open
Problem is with the ribbon cable interconnect between camera and screen. Available as spare, but very tricky to replace. Probably a camera shop is your best bet.
SOURCE: My JVC Everio GZ-MG130u does
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician. My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs. If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
