Question about Maytag MFI2269VEM 22.0 cu. ft. French Door Refrigerator with Beverage
Loud humming noise
Hello, my refrigerator is making a constant loud humming noise. It started about a week ago. I checked behind the fridge and the sound is coming from the bottom left corner where the fan is. This fridge used to be super quiet. Now it's like it is always in his cycle. Thanks.
Posted by Etienne turcodtte on
Jesse Walters
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 305 Answers
Happens when the bearings in the fan or compressor motor are getting worn out. make sure there isn't a piece of cardboard cowling or debris hitting the fan.
Posted on Jan 11, 2014
5 Related Answers
Anonymous
SOURCE: mfd2561hes Maytag Refrigerator
My Maytag mfc2560hes starting making a noise this am. I checked the fridge and everything is hot. The freezer is still cold, and the items are frozen. What am I to do?
Posted on Mar 29, 2008
Anonymous
  • 5 Answers
SOURCE: loud noise
The vibrating sound you hear could be due to "water hammer" when the fill valve tries to close against high water line pressure. I had that problem and solved it by putting a small valve in the line to the ice maker and closing it little by little until the vibrating went away. You know, the banging could also be water hammer. It only happens at night when the entire neighborhood is asleep and the water pressure is at its highest. You need to check this out because water hammer can be very destructive to the plumbing and the valve.
Tom
Posted on Oct 08, 2008
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
Posted on May 28, 2009
Testimonial: "It was the compressor. Bought a new Amana and it's great! Hate Sears still;)"
Anonymous
  • 39 Answers
SOURCE: maytag fridge has constant running water sound
you hear a constant running water sound? look in your manual under "normal operating sounds". it explains all of the sounds. it sounds like you're hearing the refrigerant going thru your evap. coil located behind the rear frzr panel. you unit goes into the defrost cycle roughly every 8hrs and water drip down into the condensate pan un the refrig.
Posted on Jul 16, 2009
dmftrucker
daniel hendrickson
  • 1922 Answers
SOURCE: My Maytag refrigerator makes a loud popping noise.
the popping noise you're talking about, could it just be your self-defroster in operation,sometimes if there a lot of ice and it operates a long time, there could be expansion noises,such as the refrigerator walls expanding/contracting from the heat of the defroster,if it's water you will hear a sizzling popping sound,nothing to fear dear
Posted on Dec 08, 2009
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerator runs way too much.
make sure it is level. the compressor is designed to run on level ground. also check the fans. if the fan is bad or the bearings are shot, it'll vibrate and make a loud humming noise. find out where the noise is loudest. if it's under the fridge, it's the compressor. if it's inside the freezer, it's the fan.
Aug 28, 2009 | Refrigerators
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
Apr 24, 2009 | Amana ASD2622HR Side by Side Refrigerator
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Candy Fridge freezer
How old is ur unit? Often the motor mount you need to check that rubber make sure its not broken (bushing)or the motor directly touch the rest of the panel below. Or else you need a new motor to eliminate that noise. Good luck Hope this help!
Aug 06, 2007 | KitchenAid KTRS22EM Top Freezer...
Maytag MFI2269VEM 22.0 cu. ft. French Door Refrigerator with Beverage Logo
459 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
