Have the JVC everio GZ-E100WU. i have a class 4 SDHC 8GB Card. Im getting the error that"this card cannot be used to record or edit" What can I do? Thanks!
The message is clear. You cannot use the card.
You can check the manufacturer's website to see if there a new firmware. If there, is update the firmware (anyway) and hope it will support the card format. If there is no new firmware, read the manual for the type of cards and capacities supported and buy compatible cards. The old card can be returned to the store, sold to someone, or saved for future devices.
SOURCE: DOWNLOADING FROM JVC GZ-MG130U
Have a look on the site http://www.convertmod.com, you will find your happiness with this wonderfull software that converts .mod files and that converts .tod files
SOURCE: JVC Everio GZ-MG130 can use as webcam?
There is a program i heard of halled trackercam but for somereason it doesnt work with my jvc, im not sure why.
SOURCE: Is there compatiblity between the SDHC card and JVC GZ-MC100?
Check the user manual and the JVC website for a new firmware.
"Can I use Multimedia Card (MMCA), xD, Micro SD, MiniSD or Memory Stick in EVERIO?"
SOURCE: I have the JVC above and it requires an SD card. I
You are correct. SD and SDHC are not the same.
Your
camera will accept a maximum SD card capacity of 2GB. It simply isn't
capable of handling anything of a larger capacity and in particular is
incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
SDHC stands for Secure Digital High Capacity. It was a technical evolution which broke the 4GB maximum capacity of SD cards and allows up to 32GB. In turn they are eventually due to be superseded by SDXC cards (ecure Digital eXtended Capacity) which allow a maximum of 2TB.
