I have a Dayton 150,000 BTU kerosene heater, model # 3E219C. he when plugged in will turn on and perform perfectly for exactly 6 minutes and then will shut down by the reset switch tripping. I wait a minute and depress the reset switch and the unit ill turn on nd run for a few seconds and turn itself back off. What should I check on the unit?
joe creger
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
Sounds like it maybe going off on a temperature limit switch units getting too hot
Posted on Sep 20, 2017
4 Related Answers
steve_lima
steve
  • 181 Answers
SOURCE: kerosene heater won't stay lit
check to see if the photo cell is clean.to check it open the side compartment and look for the blue and white wire comming from photo cell,on the reset switch there is a white wire and a blue wire.hook these two wires to gether at the switch and try to refire the unit.if the unit keeps running the photo cell is bad and NEEDS to be changed.if the unit shuts off the safety switch is bad.
Posted on Feb 25, 2009
Anonymous
  • 188 Answers
SOURCE: Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
Posted on Jun 30, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: I need a rotor pump and blades for a dayton
if you still need parts I would contact www.portableheaterparts.com and they have a rotor/blade kit for your heater or you can call them at 1-800-362-6951. You will need to giive them your model number and BTU to ensure that you get the right parts. Let me know if you need more assistance.
Posted on Jan 03, 2010
Anonymous
  • 188 Answers
SOURCE: 150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Posted on Jan 28, 2010
Dayton ready heater model 3e219c will not light
First make sure that th eunit is getting spark and the spark plugs is to gapped at .070 to .080 also you need to make sure that the air pump is working on the back of the motor.
Also inspect the black plastic cover for cracks.
Jan 08, 2015 | Dayton Heating & Cooling
How to ajust dayton 155000 btu torpedo heater when running smell like kerosen
You say: When running it smells like Kerosene--
That is what you are burning in it, right?
Is it smoking--- like there is a poor combustion mixture?
-- like maybe not enough air pressure?
There is a pressure adjustment for both-- Please check the manual for adjusting the pressures for your particular model.
Jan 18, 2011 | Dayton E50 Heater
I need a rotor pump and blades for a dayton 150,000 btu heater model number 3e219c
Lots of time if you clean the blade area and remove the thick gunk from around the cover and housingand replceblades this should do the trick...
Dec 16, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Dayton Model 1VNX5 Kerosene clicks like crazy but won't light
I have the same heater with the same problem. I took the top cover off, removed the ignitor and bent the probes slightly closer. Use two needle nose to prevent breakage of the holder. It has been working fine since.
Dec 13, 2009 | Dayton Heating & Cooling
Hi, I have a Gilson 150,000 btu Torpedo heater
go to the DESA site they have nozzles for just about any torpedo heater.
Oct 16, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Dayton kerosene heater 3E219B will not turn on
I have a Dayton Model # 3e219b 150,000 BTU potable heater and it runs fine with the top cover off.But if I put the cover on it will go out is less than a minute and trip the reset.
Jan 31, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dayton 150,000 btu that won't stay lit
see if there is a pressues switch on the heater one of the tubes could be blocked,
Feb 16, 2008 | Dayton 511 Utility Heater
Heater wont work
Dayton heaters. com?
14 years old? dayton still exist?
Stop trying to blow self up--go buy new one
Jan 21, 2008 | Dayton (3E379) Heater
Heating & Cooling Logo
239 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
