Have already replaced the supporting struts but did not fix. the squeaking sounds like rubber mounts or brakes, but can not find either in parts manual. product code 93220-B
SOURCE: squeaky operation
Hiya DIYJOE,
No regreasing possible as these are closed bearings. Just replace.
SOURCE: Maytag Mav2755AWW
hi tecate.
This can be a few things, either bearing,transmission, drivebelt or motor.
Start with the drive belt. Take it off and see if the drum when rotated makes the same squeak as befor when you apply a little pressure to the drum.
If it does not do it it can be the tension in the belt. Or the belt is gone HERE are drawings and partslist. You can also obtain the parts here
The problem as been fixed. The bearing nut was slightly lose. The bearing will need replacing in the near future as some grease has leaked from them.
