Question about Hardware & Accessories
Boiler will not switch off
Our boiler timeswitch will not switch our boiler off.
  • Amanda Drew
    Amanda Drew Aug 25, 2017
    That's strange that your boiler won't turn off. Mine has recently been acting really finicky too since it is making a really high pitched noise and just going like crazy. I think that we should probably both get a professional to look at our boilers before either of us have an emergency.http://www.esirentalboilers.com
BuladMurphy
It's important to make sure everything is okay with your boiler. That means that it turns on and works just fine when you want it to, and in the same way it should also turn off when it needs to be turned off.
Boilers not turning off might not be a problem in your home but there certainly are some homeowners who struggle with this issue. This issue needs to be fixed right away because boilers that won't turn off could increase the risk of overheating in your home. Not only that, but you'll also find yourself paying more since your boiler won't stop running.
You can check your boiler's thermostat and see if anything changes when you try to turn the temperature levels down. If nothing happens, you should contact an expert to check the thermostat. Hiring an expert offers many advantages. Your heating system professional will also look for other areas that could be causing the issue such as the valves, the programmer, and the intricate wiring inside the boiler. These areas require the skill of an expert that's why it's best to visit the website of I-Delta to get connected with a professional who will help you.
Posted on Jul 11, 2020
1 Related Answer
larry rosen
  • 17 Answers
SOURCE: timeswitch on combi boiler sticks when due to come on
best answer is to replace the timeswitch (you could try a little wd 40 but at end of day youd ony buy a few months.)
Posted on Nov 27, 2008
How do I fix a problem with my boiler not coming on?
Ive just resolved this issue on my own boiler...... Its the programmer ,replace it as the micro switch has gone , when it comes on the lights only come on the internal switch does not ,so no sognal to boiler , replace programmer
Aug 01, 2016 | Water Heaters
Boiler not coming on, programmer constantly flickers on/off
if voltage from transformer ok check to pressure switch bad or loose wire
Aug 01, 2016 | Honeywell Water Heaters
Greenstar 24i junior
Replace the thermosts,signal not getting thro to boiler.
Jul 15, 2017 | Water Heaters
Water to hot for gas boiler boiler gos off
It could be dyslexia, but I think you want to know what may be wrong with your boiler in this case!
This is a VERY old design. The diaphragm is on the water section, this operates a switch to turn ON the pump, and a further device causes the diverter valve to divert boiler water from CH duty to HW duty.
From your description it appears that the boiler is shutting down on internal boiler water temperature (too high), your 'briefly too hot' HW symptom may be caused either by the boiler side of the secondary heat exchanger being blocked/caked in sludge, OR the DHW side of it being scaled. Either way a new or replacement (descaled) secondary heat exchanger MAY inprove things. It's not easy on these old clunk-pots, and EVERY disturbed seal will subsequently leak, so get a good supply of o-rings and fibre seals before you start ("you" being the competant fitter you employ)
Dec 20, 2012 | Water Heaters
How do I wire up my IFLO TIMESWITCH 24hr 7 day
put the wire to the connector of iflo time switch . then install a on-off .that's ok ..
bathroom light
May 15, 2012 | iflo Home
What is the pressure switch
A pressure switch has many functions depending on the application. they are used in boilers to sense that there is enough water in the boiler. furnaces have them to insure the vent fan is working. pool boilers use them to sense that pumps are flowing water through the boiler. does this help?
Dec 29, 2010 | Heating & Cooling
How to check if pressure switch on halstead boiler 82 combi
Hi I am thinking what your tryig to say is the air pressure switch?
you can check this switch to see if the boiler works by removing one of the sensing tubes from it & by sucking on or blowing as this willactivate the switch you dont have to do it very hard, just gently as you will hear the switch clicking, if the boiler does fire when you click, in order for it to continue to ignite you may have to fold over the tube, when you release it the boiler should stop.if it does work then you will have to change the air pressure switch, but remember this can only be done by a Corgi Engineer
Kindly
Richie
Dec 17, 2008 | Water Heaters
Timeswitch on combi boiler sticks when due to come on
Nov 07, 2008 | Water Heaters
Valliant timeswitch 110 heating system fails to switch on when on constant setting??
check the timer switch, there is a micro switch inside that could have been damaged.
tnx 4 using fixya,
drcool
Oct 04, 2008 | Heating & Cooling
Hardware & Accessories Logo
402 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
