SOURCE: Shredder won't run
I had similar problem. I took unit apart and checked the motor by hotwiring it after checking voltage coming off the circuit board connections that the motor is connected to. Motor did not run until I tapped it a couple times with a hammer. Seems ok now.
SOURCE: ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
SOURCE: I can not get the
Dont wont to do if shredder is under warranty. If not, you will usually see a sticker staying that if you remove this sticker you warranty is voided. There is a screw that holds the top on. If you take the sticker off your warrranty is voided so beware.
