Question about Integra DTR-7.1 Receiver
No sound arrived home, turned on the system and everything was working fine. After a few minutes the sound stopped working. we have a picture, but nothing else.
Posted by Doug Wright on
Jerry Kramer
  • Integra Master
  • 3,904 Answers
Sounds like an input button has been changed. Check that out first
Posted on Jan 11, 2014
Picture on my sony 29" cuts out after a few minutes
I once had this problem.I unplugged it for a few minutes then plugged it in it worked , but then i took it to repair it and everything was fine
May 18, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No sound from hdmi cable
PS3 is The amazing device by sony but it has some common problems like sound but no video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Nov 24, 2008 | Sony Playstation 3 (PS3) Console
RCA Home Theater (Model #P46924) No Picture, just sound
Sounds like a possible solder issue with the vertical output IC. Try resoldering the Vertical output IC connections
May 17, 2008 | RCA P46924 46" Rear Projection Television
Picture Fades
The more you play set the longer it will last, it sounds like you may have poor connections, cold solder joints try soldering around flyback transformer.
Apr 03, 2008 | Zenith R56W36 56" Rear Projection...
Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
Oct 06, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Picture and Sound disappear after a few minutes
Practice visual acuity technique! Look for bad solder connects==none found?? suspect flyback xformer.
Sep 26, 2007 | RCA F36674ET 36" TV
No sound
have you check with other input like a vcr?...good luck
Aug 10, 2006 | RCA F32649 32" TV
Integra DTR-7.1 Receiver Logo
102 people viewed this question
Top Integra Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Larry Stiles
Larry Stiles
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
