1999 Saturn SL Logo
Posted on May 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Car will not start after installing CD player into a 1999 Saturn!
When I replaced the stereo in my daughter's car I lost power to the Ignition. I still have dash lights. But no power at the stereo and the car will not turn over. Also the keyless entry stoped working. How do I reset them? My 1999 Saturn will not start after installing a new cd player. Power windows and headlight lights work, but cd player and keyless entry do not work and car won't start. Checked the battery and it seems to be fine, so do the fuses. Help!!
Anonymous
Level 2:
  • Expert 186 Answers
  • Posted on May 27, 2009
Anonymous
Expert
Level 2:
Answers
186
Questions
Helped
116420
Points
502
Check your Ignition 1 & ignition 3 fuses in the inside fuse block,also check the body fuse 10amp in the inside fuse block.Keyless entry should take back off once you found the blown fuse.hope this helps
How to fix .
post symptoms like this.
i check head lights, they work key out , so do they?
i turn the key to Ignition on.
the dash self test lamps all glow, do they,?
look at that CEL lamp, (aka SES) lamp, check engine lamp
it it dont glow the engine brain, lost power, fuse, (head lamps work)
if the CEL glows. then now crank the engine, (start pos.)
does it crank robustly? yes /no?
yes, do you have spark>
no, does car crank over fast with jumper cables to running donor car?
that is start, no pun.
1helpful
2002 saturn lw 300 radio quits
Yes it can be Amp problem,but there are many other possibilities like loose connection,radio wires getting short.
I suggest you to go through the troubleshooting help links related to car radio problems.
Click the link below:-----
Radio goes ON and OFF while driving?
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
Cigarette lighter, Remote central locking, and Radio stopped working http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe mode? VW radio CODE? http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
How to wire new Radio on 1990 Toyota Celica?
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
Radio Stereo Wiring Diagram for 1991 Chevy 1500?
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
How to remove radio on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
Where is Radio Fuse located on 2007 Dodge charger?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
How to reset Radio code after car battery is died?
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
Can car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
After Market Stereo wiring for 1999 Chevrolet Silverado 1500?
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
Chevy car radio doesn't allow to switch to the XM Band to get the radio ID?
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
No power to radio on 2005 Toyota Scion Xb?
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
Lexus rx330 Radio has power but no sound?
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
Lincoln Town Car Radio stereo wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
Radio wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
How to remove cd player from dash on 2003 Lincoln Aviator
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
These details will help you thanks.
1helpful
Changed Radio and now car won't start
What stereo did you use as a replacement? If you used a aftermarket (kenwood, sony, etc) cd player, you need to use the proper adapter harness. These cars have a build in theft deterrent system that involves the stereo. So, when you replace the stereo, a component of your anti theft system is missing. The use of the harness gets around this feature somehow, and allows you to use aftermarket CD players. Also, ensure that no wires are getting pinched behind the stereo, and that all your connections are soldered and shrink wrapped to avoid any future problems. I have provided a link for the correct adapter harness to your vehicle.
http://www.amazon.com/Stereo-Harness-Oldsmobile-wiring-installation/dp/B000KL2PEI
Cd player keep ejecting cd and want play
find yourself a replacement radio/CD unit on ebay and pay a car stereo place 20 bucks to install it for you. stick with one made for the year and model saturn you have. that way it will just plug in.
97 Saturn sl. battery went dead,,replaced
Did you check the alternator? if it is faulty the car will drain all the power from the battery until it goes flat
99 ford explorer new battery and good starter... i installed an aftermarket cd player and my car will not start now
Start by checking all your fuses. also, where did you hook direct power to for the stereo? That could be a problem.
1helpful
2answers
I Need the Wiring guide
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black
Car Stereo Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
1helpful
When I replaced the stereo in my daughter's car I lost power to the Ignition. I still have dash lights. But no power at the stereo and the car will not turn over. Also the keyless entry stoped working. How...
car stereo that come with car is program to car pcm security system.when you change stereo.the pcm dont recognize the new stereo.the pcm goes into anti theft mode it disable ignition.system.
Car wont start but theres power
you have a wire gounding out somewhere. Take out the dam# stereo and get with the times and just get a MP3 player.
2001 sl saturn cd stereo
yes you should of recieved a cd when purchased the car that has the programing codes on it if not then dealership may have it
Top Saturn Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Saturn Expert? Answer questions, earn points and help others
