Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Change video input without remote
No longer have remote and need to change input source using buttons on front. Source button works, used channel button to move down to desired input, but don't know how to "enter".
Posted by Catherine Tanner on
  • Catherine Tanner
    Catherine Tanner Jan 11, 2014
    I finally got it to change input. After using the channel down button to highlight the desired input, I pressed the volume + button and it worked. Just got it working a few minutes ago. Thanks for trying, though. This solution might work for others; you never know.
  • David Wu
    David Wu Nov 19, 2021
    thanks, this helped. I got it
ADMIN Andrew
    Top Expert:
  • Akai Master
  • 55,621 Answers
Normally you HAVE to use the remote. If it is on the television, there is normally a 4 arrow button and there is a button in the centre which is enter.
Remotes are easily sourced and a authentic copies of the original. Google
make model replacement remote
Posted on Nov 19, 2021
5 Related Answers
Anonymous
  • 2712 Answers
SOURCE: Volume stuck in 100% flashing
Since this is a digital LCD TV, there is no question of any button being "stuck". It is most likely an issue with the circuitry. You can try a hard reset first, which is the basic step. Unplug everything, including cables and power supply, wait about 1/2 hour and replug everything. Should the hard reset work, well and good. If not, you will have to take the TV in for servicing. I do not recommend a DIY if you have no prior experience, as there are very sensitive parts within.
However, if you would like to try a DIY, you will first need to get your hands on a service manual. I recommend the following site:
http://servicemanuals.vstore.ca/
They also help you procure the needed parts and provide free diagnostics and help while you repair the set online (provided you buy the manual from them, of course)
Hope that helps! If there is anything further I can assist you with, please let me know. If you are satisfied with my response, kindly take a moment to "ACCEPT" my solution.
Cheers!
IrishDruid
Posted on Sep 08, 2008
Anonymous
  • 48 Answers
SOURCE: hdmi receiver to hd plasma tv
1. You cannot get and HDMI and component on one cable. One is anaglod, and HDMI is digital. Use the component, the difference isnt. They are both HDTV compatible signals. S-Video is terrible, its really no better than the old-fashioned coaxial cable. After you connect the two, be sure you go into the settings on your home theater and set the output to component, progressive scan, and the the resolution your TV supports. The resolution is clearly stated in the user manual and on the box. It is probably 720p or 1080i. (Dont worry, most HD devices will revert back to the settings if they dont work. So if it goes blank or you see undesired picture, just wait up to 15 seconds and it will revert your settings. Once you are successful, the menu will ask you if you can see the picture, use the remote to select yes.)
2. The remote came possibly with an auto scanning feature, but at least has a code entry mode to program
your brand of tv to work with your remote. Look at the list of codes based on category and brand in the documentation for the home theater system. Use all the codes available for your brand unil the tv responds to the code you entered. This is very brief but the manual has very specific instructions on what to press, step by step.
And the last question is absolutely yes, the picture is about 6x better than the regular tv standard which is 480i
480i is an interlaced picture, and its 320x480 dots of color to display your picture, interlacing is basically using one horizontal line to act as 2 by quicly alternating what it draws twice per frame. Thats why standard tv seems to "jiggle" in place
 Progressive Scan has a solid image, every time, that automatically doubles your quality. Definitely, you want your resolution to be as high as the tv supports and you will be satisfied.
Posted on Jan 07, 2008
Anonymous
  • 186 Answers
SOURCE: input source change on remote for tv
Are there not enough ports? You can buy port splitters to add more connections to your tv. Also, some surround sound receivers have port switchers too.
Posted on Apr 26, 2008
Anonymous
  • 35 Answers
SOURCE: Unit powers on, but SOURCE button cannot change screen from VGA
Hi
You have main board problem and coast for you with shipping $130.00.But we do only exchange.Please look at our policy:
ATTENTION:
WE CHANGE YOUR BAD MAIN BOARD TO GOOD ONE.
OUR POLICY
1.YOU HAVE TO SHIP AN OLD MAIN BOARD TO US
WE WILL SHIP NEW ONE TO YOU BY USPS IN 2-3 BUSINESS DAYS.
2. PLEASE PAY TO PAY PAL BUY FOLLOWING EMIL ADDRESS:
[email protected] 3. PLEASE SHIP YOUR OLD MAIN BOARD TO FOLLOWING ADDRESS:
GEORGES ELECTRONIC
769 GLADYS AVE
LOS ANGELES CA, 90021
PHONE: 213 627 4071
FAX: 213 627 3944
THANKS
GEORGE
Posted on Mar 17, 2009
skotkolr
Scott Hill
  • 558 Answers
SOURCE: lct2785ta will turn on and back light lights with akia name but
E BAY!
Posted on Apr 05, 2009
It only shows cable link not digital or air It use to hook up the antenna but someone in family messed with the remote. So no longer allows that option. How do I fix this?
First check the current source (input) on the TV. Without knowing the model of the TV, I can only recommend you first look for a source or input button on the remote or on the front panel of the TV. Press this button multiple times if needed to set the source to TV. Press OK on the remote or Select. (On some TV, just waiting after highlighting the desired input will lead to the switch.)
If you don't see that, see if there is a Menu Settings option on the TV that lets you chose a source. Once your source is TV, see if you can access the Menu sub-section for the RF (coax) tuner settings. Most TVs will blank out the TV antenna/cable selection and channel search options when the source is not TV.
I hope this helps.
I want to set up for antenna for local channels. I have searched the menu but cannot get correct set up
First check that the source or input is set to TV (RF) port. Some TVs only have the Source/Input button on the original remote. Others have one among the front panel buttons. If this button isn't on the TV itself and you have an universal remote, you may need to try multiple codes to get the Input/Source button to work properly. Getting the power button to work is often easier.
I hope this helps. Every TV that I've used only displayed the Channel Search when the input was TV. It could be in a Setup menu, under Initial Settings or a Channel menu. Please add a comment with the make and model of the TV for more information on where to find the Input/Source button and the Menu location to for searching for channels. (Note: there was a brief period of HD monitors that were sold as HD-ready TVs. However these units didn't have a tuner. They were meant to be used with a set-top (satellite dish receiver, cable) box.)
Can't change the menu from the clock set up to other functions such as channel scanning.
Are all of the sub-menus besides the clock unavailable or just the ones related to OTA (RF) signals? If it's just the OTA menus that are missing, change the source/input to TV. On all of my TVs, the channel scan option and related functions are blocked if the current input is not TV.
Changing the input/source depends on the TV. First make sure that an antenna or cable source on an RF (RG-59/RG-60 cable) is connected to the set. Next look for a Source or Input button on the original remote. Press this button. On some models, you navigate through the menu by pressing the Input/Source button repeatedly and then press OK to change the input. On other sets, you navigate with the arrow keys and then press OK. Some TVs may switch to the new source after a few seconds without any button presses; they don't need the OK button to be pressed. On a universal remote, you may find an Input/Source button but the button may not work with some codes for the manufacturer. (This can be frustrating since the basic functions (power, channel up/down, volume up/down) work; try a different code.)
Some TVs will also have an Input/Source button on the TV. This will work like the button on the remote. Use the Select button for the OK button. A few TVs have the option inside the on-screen menu. Press Menu and then look for a source option in a Tools or Setup menu.
I hope this helps. I have never had a TV where only the Clock menu is available. If that is the case with your TV, I don't know of a solution.
Can I change HDMI1 to HDMI2 or Video manually without the remote
On some TVs, you can change inputs by using a Source or Input button on the TV. These front panel buttons may be on the bottom of the TV bezel, on the right hand side or on the back on the right side as you face the TV. Once you locate the FPA buttons, you either press the Input button several times. Press the Select equivalent or just wait for the input to change. Alternatively, you need touse the Channel or Volume buttons (one pair becomes Up/Down, the other Left/Right) to navigate through the list. Then hit the button that gives the Select equivalent. A few models let you change inputs after pressing the Menu button on the TV and moving through the on-screen menu to a Source sub-menu. Not all TVs support this.
Please add a comment with the manufacturer and model of your TV for specifics that apply to your TV.
I hope this helps.
(Note: if you replace your remote control, check for a Source or Input button on the universal remote. Then try multiple codes for your TV brand to find a code that gives the input function properly.)
Our tv says 2-1 instead of hdmi.
Your television source has been changed to OTA and is tuning in the digital channel 2-1. Depending on the TV, there will be a source or input button on the original remote. You either press this button several times to change the source or you use the arrow keys to navigate through the list. You may need to press OK/Enter to confirm the selection. Some TVs also have a source/input button among the TV front panel buttons. Again you press the button several times or use the arrow key equivalents on the front panel to navigate through the list. On a few TVs, changing the source may be inside the on-screen menu. If you have a universal remote, it may match the source/input function. However, this depends on if the best code is programmed. (Some codes for a given brand don't match all of the functions for a given TV.)
Please add a comment with the make/model and the remote (if not the original remote) if you need help changing the source.
Model LED2845A in setup I can't access the channel scan. I was able to access it when I first turned it on but can't any longer.
Check your current input. Use the Source or Input button to ensure that the TV is set to TV mode; there may be one on the TV in addition to the one on the remote. The icon may look like a rectangle with an arrow coming into the box from the left. The Channel Scan option is only available when the tuner is the active input. If you are using a universal remote, you may need to use a different code if the Input/Source button doesn't work. (Some universal remotes don't match this function at all. In that case, use the front panel button to change inputs.)
I can't find the model LED2845A TV. I see a Proscan PLED2845A and an RCA RLED2845A. The Source buttons are in different places on both the front panel and the remote on the two brands. Please add a comment with the brand of your TV if you would like to see where the buttons are for your model.
I hope this helps.
How to change input on tv without a remote
Which TV do you have? Some will have an Input or Source button on the front panel. A few will have an option to change the source from the menu. Both of these options require the front panel lock to be inactive.
A few older TVs allowed you to find the A/V input by pressing Channel Down on the front panel buttons until you passed channel 2 (or Channel Up until you nearly reached Channel 2). This option wouldn't work if the A/V inputs had been deleted when someone minimized going through unused channels.
If the Source or Input button was only available on the remote, you will need a universal remote that includes this feature. These cost a bit more than the lowest end remotes. Then you will have to try all of the codes to find the one that makes the Source button work with your TV. (Several codes may work for On/Off but not the change input.) The Universal remotes that can be programmed from a computer (USB connection) will be the easiest to set up. Remotes.com may have a replacement original or substitute remote for your TV that should work for all of the TV functions.
I hope this helps. Please add a comment with the TV make and model for specific options for your particular TV.
(low end TVs usually only had the Source/Input button on the remote.)
2answers
Change input without remote
Go to menu on front of tv, scroll down to source/input heading.Use the volume or channel select buttons to change the source
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, [email protected]
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
