I have tried both the pogo apps and they are useless, the pogo app only prints after you have changed the colour etc, and the pogo print app can't print a single picture, you have to have two or more on the same sheet. I can't understand why it's stopped working, it will sometimes print but not the ones I want
SOURCE: can you connect a PoGo
I connect to my pogo via bluetooth with my laptop, To print a picture - Right click on the picture file and send to the bluetooth device.
I would love to see a rinter driver for it myself.
Posted on Feb 15, 2009
SOURCE: bought today..does battery have to be charged for 3 hours before use? please advise
first of all make sure that the pogo it turned off insert the paper from the packet with the blue peice on the bottom with the barcode facing down. and the paper facing shiny side up and logo face down. when you turn the pogo on the blue paper will feed through first then the printer is all setup and aligned ready to print via bluetooth or via USB cable. hope this helps
Posted on Oct 30, 2009
SOURCE: Have just bought a Pogo printer.
If you are printing from a PC/Mac via Bluetooth, It won't accept anything other than Jpg's and also if the file name is too long (or if the file has multiple .'s in the name as I just found out)
Posted on Nov 04, 2009
SOURCE: I cant print using my phone even tho it has
LG phones seem to send images with characters other than 0-9 and A-Z in the image filename. It looks like either the Pogo, or the LG phone bluetooth software doesn't accept this (I see "disconnected" if I try to print an image with a filename like that)
This solution "works" to the extent that renaming the file helps, though I don't know how to avoid these characters appearing in the filename of the photo in the first place :
http://www.fixya.com/support/t3651208-kp500_lg_cookie_compatible_pogo
Posted on Jan 06, 2010
SOURCE: I successfully paired my Pogo with my Samsung
I had the same problem with my samsung fascinate. I called Polaroid and they told me the phone is not supported and they could not help. I tried something different and it worked!!!! I downloaded the polaroid PoGo app in the android marketplace(free app). Print your pictures from the Gallary thru the app. It works fine. All my pics print and there is no more problem. Give it a try
lloyd
Posted on Dec 17, 2010
