Question about Mercedes Ml Ml320 Ml350 Ml550 Ml63 Chrome Exterior Accessory Abs Molding Trim Kit Set 2006 2007 2008 2009 2010 2011
Code reader Dose anyone know of a diagnostic code reader that can be bought aftermarket and reads a Mercedes ML320 2000.. hoping its less then taking it to the Dealer...
Posted by David Williams on
doko543
    New Friend:
    Problem Solver:
  • 8 Answers
It may not help you to know the error codes.
only Mercedes dealer can read all error codes via OBD.
Posted on Jan 13, 2014
1988 Mercedes 260e will crank but will not start
Any fault codes? The very 1st thing you need to do is read the fault codes. See link. Mercedes Benz Diagnostic Code Reader Tools Sale 1987 1995 Easy to use pays...
Aug 16, 2018 | Cars & Trucks
Code maintanance 8800
Where are you reading this code? I need the standard OBD2 fault code that is read through the diagnostic port under the dash, borrow a reader repost
Sep 21, 2016 | 2003 Mercedes-Benz SL-Class
Hello.. my 2002 Mercedes benz S320 idles but does not rev at all and has a check engine light on can anyone help please
Sounds as if it is in emergency service mode , if you can obtain or borrow an OBDC II reader ( I thinks it's OBD2 for that model ) it will show you the scan of the engine management diagnostics and give you fault codes corresponding to the faults in your car ( Know as DT's ) look on the Mercedes forums and they will tell you what fault codes mean .
Jul 03, 2015 | 2002 Mercedes-Benz S-Class
Vehicle Diagnostic Code Reader dose not work
THE MAIN POWER FOR OBD2 COME FROM CIG LIGHTER FUSE.
IF FUSE IS OK SCAN WITH DIFFERENT SCANNER.SOME TIMES CHRYSLER DON'T LIKE GENERIC SCANNERS.
Mar 27, 2014 | Jeep Liberty Cars & Trucks
ESP and cruise control warning came on and said to visit work shop, any idea what this means?
The engine light is telling you that the CPU has found sensor/s outside set parameters during the checking process. Have the fault codes read before wasting time and money guessing what has failed. Replace with genuine items only as aftermarket units are not always compatible with the settings in the CPU. Have the fault codes read as it may be serious and need attention . Reset the cpu after by using the fault reader
Jun 19, 2013 | Mercedes E-class Pillar Posts Trim Set
How can I get a diagnostic code reader to link with my jetta?
You need to have power at pin 16 which is B+ or (12volts) because what you bought does not supply the power 3_25_2012_8_31_32_pm.gif
Mar 25, 2012 | Cars & Trucks
Car wont start, Merc/Benz C240 2001
it could be a number of things. oil pressure switch, fuel pump relay or fuse. fuel pressure switch/regulator. something like this would help you find the fault https://www.ebay.co.uk/itm/Mercedes-Benz-MB-OBD2-CAN-BUS-Fault-Code-Reader-Scanner-diagnostic-scan-tool-UK/221097686022 just to read the fault codes.
Feb 10, 2018 | 2001 Mercedes-Benz C-Class
Where can I find a diagnostic computer plug for a 1989 mercedes benz 300 SE?
It is over by the battery, go to benzworld.org or peachparts.com on how to make a code reader and how to read the codes you find.
Apr 29, 2010 | 1989 Mercedes-Benz 300-Class
Mercedes SE 300, acts like its coughing, my husband said, coughing through the intake. Not a regular thing, very intermittent, more noticable when I come to a stop. I thought maybe it was bad gas, bought...
Have the cars on board diagnostic system read. An autoparts store like Autozone will plug in and read the codes for free sometimes if you are at their store. Or just visit a trusted local garage and ask for a read. It only takes a few minutes to read the computer with a industry standard OBD2 code reader. I bought one on ebay for 35 bucks for myself.
If you have codes but no continuous "Check Engine" light showing on the dashboard you may have missfires related to certain controls/sensors slowly going bad on your engine. Or you could have something outright mechanically wrong with the car like a vacuum leak or a clogged EGR valve.
Also, is this coughing causing other driveability or fuel ecomony or power issues? That can also be indicative of what kind of problem you are looking at.
If this problem persists but is minor....eventually the computer will send you the check engine warning. Sometimes it takes 1000's and 1000's of missfires to get a check engine warning! That's because of tolerances built into the software the cars computer is using.
Dec 16, 2009 | Mercedes-Benz S-Class Cars & Trucks
Mercedes Ml Ml320 Ml350 Ml550 Ml63 Chrome Exterior Accessory Abs Molding Trim Kit Set 2006 2007 2008 2009 2010 2011 Logo
223 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
