At the stopping point, when pulling vacuum back, leaves a line of dust the width of the vacuum. Has new belt, and is not clogged in any place I could find.
SOURCE: when I pull back on the vacuum cleaner, it leaves
Hi there, SmartAlec from NelsonVacuums.com.au here. What you are describing is a pretty common problem, it is normally caused by a blockage or a brocken belt, or if you are really unluck ..both. Take the base plate of the bottom of the vacuum (part that kind of covers the brush) and check your belt and air path. 9 times out of 10 this is where your problem will be. Clean the pathways and away you go.
Happy Vacuuming :)
ps. If you are in Australia and need spares or parts for any Bissell machine simply visit our website. We'll be able to get you anything you need.
