Question about SanDisk 4GB microSD High Capacity Memory Card
SERIAL NUMBER IS O8DO-ACD5volume name
My memory was 4gb an now is 30mb how can retern my old sistem
Posted by ahmed on
Lawrence Oravetz
  • SanDisk Master
  • 10,548 Answers
Try reformatting it
Posted on Jan 17, 2014
1helpful
Have ipad3 can I find how old it is
Nice Name: iPad 2
Machine Model: iPad2,1/iPad2,4
Name: iPod (Generation 2)
ModelCode: ipad_2
Family name: A1395
Model Number: MC979
Group1: iPad
Group2: WiFi
Generation: 2
CPU speed: 1.0GHz
Screen size: 9.7 inch
Screen resolution: 1024x768 pixels
Colour: White
Production year: 2013
Production week: 30 (July)
Model introduced: 2011
Capacity: 16GB
Memory - flavour: xx
Factory: F5 (Refurbished?)
30MB memory PSP 2000 ask for 32Mb memory to update it.
If yoy want a bettermemory then purchase a spiral notebook.
6helpful
1helpful
My SD card is 4gb now its showing 30mb and I can't format
You have to be the computers Administrator to change any values on any Hard Drive on your computer. Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control. Click start click to open on my computer you should see your Usb drive E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions. Make sure all 3 boxes are ticked full control change and read in windows 7. Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP. Click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Click start control panel administration tools computer management disk management right click on your usb drive select properties click tools you should see click check now click start two boxes Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive Click start click on my computer to open you should see your drive right click then select format another way Click start control panel administrative tools computer management disk management Right click on your usb drive select format.
Hope this helps.
Do you help in recoverying stollen acer computers? serial number EXDXF0100302315B552000
hi,
in that case you have to contact your laptops manufacturer (ACER) to report the incident and provide the serial number of the laptop.
I have been using a 4gb micro sd memory card when i format card its showing windows was unable to format & displaying 30mb size of card
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Accepte my greetings
    How to find Sandisk cruzer 4G USB drive serial number? Embeded serial number how to find
    Try using Belarc Advisor with the USB drive plugged in. Read the report to get the serial number. Hope this helps.
    5helpful
    I have nokia 5130 xpress music and my phone memory reduced from 30mb to 3mb
    i have nokia 5130 xpress music and my phone memory reduced from 30mb to3mb
    SanDisk 4GB microSD High Capacity Memory Card Logo
    Top SanDisk Electronics - Others Experts
    k24674
    Ekse
    Mehandi Husain ...
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
