Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
Rose Moon Posted on Jan 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 596.73503201 frig warm, freezer working
Frig is warm, freezer is working. Tech said to unplug it to defrost it and try it. Still not working. Fan problem?
Paul G
Level 2:
Scholar:
  • Expert 161 Answers
  • Posted on Jan 11, 2014
Paul G
Expert
Level 2:
Scholar:
Answers
161
Questions
0
Helped
48165
Points
422
Check your duct from freezer section is open if it is check that fan is running ,if it's not the fan is faulty and needs to be replaced
5 Related Answers
Anonymous
  • 481 Answers
  • Posted on Jul 18, 2008
SOURCE: Kenmore refrigerator 5260 not cold
  • the defrost timer on your machine is actually integrated within a control board/air diffuser. hopefully that is not the problem (expensive).
  • i would start by testing the heater and bimetal thermostat in the freezer. (note: the bimetal thermostat will only have continuity when below 40 degrees.)
  • the heat you feel between the doors is normal (if it is not too hot).
  • some of the heat that is released by the machine is intentionally released between the doors to prevent condensation.
  •  if it seems warmer than usual then you might need to clean the coils under the machine and make sure the airflow under the machine is not obstructed at all.
  • if the coils are dirty then they will not be able to release the heat properly and the heat will be released in other areas like between the doors.
Anonymous
  • 111 Answers
  • Posted on Aug 01, 2008
SOURCE: freezer works but frig is not cooling
I don't know this particular frig, but evidently the defroster doesn't work. Frost buildup has blocked the flow of cold air.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Anonymous
  • 112 Answers
  • Posted on Oct 27, 2008
SOURCE: Freezer and frig is not working
I would start by pulling it out, removing the lower back panel, and see if the compressor is running. It is the black ball on the left side. If it is not running, check voltage at the two wires at the compressor. If there is voltage, try a new overload/relay kit. If there is no voltage, try a thermostat. If the compressor is running, check the evaporator behind the rear freezer panel to see if it is frozen solid, if it is, replace the defrost timer.
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Feb 06, 2009
SOURCE: Kenmore Frig-bottom freezer/freezer door pops open
Replace a door gasket on a refrigerator....
Replace a door gasket on a refrigerator: The first thing to do when changing a door gasket is to check and see if you have the proper part before taking the old gasket off. Hold the new gasket up to the fridge door to make sure the gasket is the same size as the old one. Next step is to remove the wrinkles in the gasket caused by folding for shipping. Instructions with the gaskets say to soak the gasket in hot water. Another way is to use a hair dryer to heat the gasket and remove the wrinkles. Be careful not to burn the gasket with the hair dryer. Almost all gaskets in use today are magnetic. I am placing instructions here for the most common one. They have strips of magnetized material inside the gasket material to adhere to the cabinet when the door is closed. Therefore there is sometimes no up or down on the gasket. Some fridge's have magnets on only 3 sides and the side without a magnet is the hinge side gasket. But to be safe, check this before installing. You will certainly want to check for this on older refrigerators that have magnetic door latches. Some of these have no magnets on the latch side of the gasket. There are about three different ways of attaching gaskets. All will be addressed on this page. Remove the food from the shelves on the door. Loosen the screws that hold the metal strips that keep gasket in place on the top half of the door. Back the screws out about 1/4 inch. The gasket has a lip on it that seats in a groove under the top part of the metal strip. Pull the old gasket off. Work the groove on back side of the new gasket under the cutout in the metal strips that holds it on the door liner. Straighten and get good install before tightening screws. Run screws back up against the metal holding strip snugly, not fully tight. Go to the bottom and do the bottom half. By doing the top half first and tightening, then doing the bottom half, you will minimize any warping of the door. If there is warping of the door, we have not yet fully tightened the screws. so you can realign the door easily and then tighten the screws. Check the alignment of the door and be sure the gasket is sealing properly before fully tightening the screws. If the door is warped, (see picture) simply warp it back to a sealing position, then tighten the screws. There are instances where the gasket is too tight on the hinge side, and you may have to shim the door hinges out from the cabinet to keep the gasket from scrubbing when closing. .also use a little petroleum jelly on the gasket on the hinge side will allow the gasket to "settle" better. The hinge side must slide along the cabinet edge while the other 3 sides just close up against the cabinet. The jelly will allow the gasket to rub smoothly and also prevent squeaking noises. Maintenance of the gasket is important also. It should be cleaned on a regular basis. Clean the gasket and the mating cabinet surface with warm soapy water, rinse clean and dry it good. Putting a little baby powder on the sides (except the hinge side because we put the jelly there) will prevent the gasket from sticking and tearing. The heaters in the refrigerator used to keep moisture from forming on the cabinet attracts airborne materials and make the gasket sealing surfaces sticky. The powder will help stop this. Probably 75% of the fridge's made a few years ago use this edge under the metal track....some American made fridge's use the U shaped metal strip and the gasket pushes into the metal strip, (see a picture) the screws that hold this metal strip do not have to be removed or loosened. A lot of fridge's also use the metal strips with out the edge. Some Maytag's and Woods come to mind. The screws go through the metal strip and the gasket as well. The screws have to be removed completely to replace the gasket.
Gasket sheet to assist you in replacing a common door gasket.
Freezer door pops open when I shut the fresh food door:
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
I hope this helps, and if you need more information On solutions just let me know, Thanks Sea Breeze
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Aug 27, 2009
SOURCE: freezer is working fine, but frig is warm,
Look for the return vent near the bottom probably behind the crisper. You'll have to remove it to see the vent. There may be an adjustable flap in to to adjust the meat keeper area. Make sure it's open.
GE Profile PGSS5NFXA SS Refrigerator Freezer; the frig warms up?
The problem is most likely to be the defrost heater Check the back of the freezer compartment for frost If you have frost on the back wall of the freezer compartment you will need to unplug the unit and remove everything from.it next get several towels to place on the bottom of the freezer to catch the water from the melting frost Using a hairdryer heat the frosted area to defrost remove the back panel of the freezer under it you will see a frosted up mess after defrosting you will see one or 2 heaters mounted on metal brackets they unplug and can be tested using a ohmmeter or continuity tester also check the defrost thermostat an replace defective items.put it together you should be all set
Unplugged frig overnite once I plugged back in made a gurgeling sound whenever I opened the door what would that be?
Usually that is caused by a bad defrost heater thermostat or defrost timer. Failure to automatically defrost is the cause of freezing up.
If you don't feel up to doing the work yourself you should have an appliance repair shop look at it.
The gurgling is caused by water in the catch pan under the fridge. When you defrosted it some of the water made it into the drip pan (and maybe overflowed onto the floor). The fan inside the compressor area under and behind the freezer may be splashing in the excess water in the drip pan. This by itself is not a real problem since it is designed to automatically evaporate the water drained during automatic defrosting, but the excess water and potential overflow onto the floor can become a problem.
1helpful
3answers
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
1helpful
Temp is erratic too warm, too cold ....
Sounds like the defrost timer is not working correctly or the start capacitor is malfunctioning,Both are cheap and easy fixes.
Kenmore side by side frig not cooling in frig comparment and
Something has failed in the defrost circuit-
Defrost thermostat
Defrost heater
Defrost timer
Reply back if you know how to diagnose electrical circuits, and I'll help you further.
Refrigerator not cool
Freezer works but frig is not cooling
1helpful
Duct from freezer to frig is blocked with ice, frig warm
give the unit a full defrost then unblock the drain hole. it sounds like the tiny defrost heater element may not be working and is therefore causing excess frost to build up on the freezer evaporator. also check door seals are not holled anywhere.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
