My dryer stopped working in the middle of a cycle. There seems to be no power at all now. The power comes first through the washing machine that is plugged then transferring to the dryer. The washer has power...but not the dryer. I changed the 2 fuses in the dryer electrical box (15amp 250v).Still no power. Any suggestion? thx
SOURCE: my dryer is not doing anything
Thank you for the useful tip, I also had the same problem and the thermal fuse was the problem...
SOURCE: WHIRLPOOL ELECTRIC WASHER STOPPED WORKING MIDWASH BC OF OVERLOAD?
My wife did the same thing,trying to do all the laundry at one time.Even if it says high load compasity it will only handle so much.sounds like you killed your motor.Hope this helped.
For more help go to live chat.
lenwest
SOURCE: asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
SOURCE: Asko T700 dryer won't run
Have you checked the 15amp fuses which are located at the back of your Asko dryer ?
That is where I`d start. They are at the back as I said located next to where the power cord exit`s the unit. Look for 2 small round slotted caps ( these are the fuse holders/hubs ) either black or gray in color.
With a flat screwdriver fitted in the slot of the fuse hub, turn it a half turn counter clockwise an it should drop out...though it may need to be pulled out if it`s stuck in the holder part.
Replace with a 15amp "slow blow" ( the only difference is the slow blow are filled with sand and aren`t transparent glass tubes but rather gray or white in color ) if the fuse is blown.
Hope that is helpful. If so please rate the solution accordingly, if not let me know what you find or if you require further assitance.
Thank`s for visiting fixya today and good luck.
macmarkus :)
Testimonial: "Very helpful-fuse was bad-I will replace and see if there are additional problems. I will use Fixya again."
