Sony DVP-CX850D DVD Player Logo
A
Anonymous Posted on Jan 10, 2014
Factory reset button - Sony DVP-CX850D DVD Player
2answers
How can we reset our DIGNO WILLCOM Mobile
  1. urn off the phone: Press and hold the power button until the power menu appears, then select "Power off."
  2. Enter recovery mode: To enter recovery mode, press and hold the volume up button and the power button until the WILLCOM logo appears.
  3. Select "wipe data/factory reset": Use the volume down button to navigate to "wipe data/factory reset," then press the power button to select it.
  4. Confirm the reset: Use the volume buttons to navigate to "Yes - delete all user data," then press the power button to confirm.
  5. Reboot the phone: After the reset is complete, the phone will automatically reboot.
If you have forgotten your mobile code and are unable to access the phone, you may need to perform a factory reset. The exact steps may vary depending on the model of your DIGNO WILLCOM mobile phone, so refer to the user manual or contact the manufacturer for more information. Keep in mind that performing a factory reset will erase all data and settings on the phone, so it is important to backup any important data before proceeding with the reset.
Feb 07, 2023 • Cell Phones
Factory reset Samsung SGH-T528 with buttons
Hi, I understand you want to factory reset your Samsung phone.
  • First, turn off your Phone. (By pressing the power button and confirming to turn off)
  • Press and hold Volume Up, Home, and Power buttons until the vendor logo appears on the screen. (Hold all these buttons simultaneously)
  • Then scroll to Factory Reset Option. By pressing the volume down button, then confirm the factory reset option with the power button.
  • Confirm factory reset scroll to yes and confirm by pressing the power button. (This will factory reset your phone and delete all previous data)
  • Let it reboot, this will take about 2 to 5 minutes and you are done.
I have a Yamaha dtexpress. Very old, but works great. Except the snare sound. It is stuck on bongos. Is there a factory reset for the dtxpress?
It's possible to reset the DTXPRESS electronic drum kit to its factory default settings by performing a Factory Reset. Here's how you can do it:
Press and hold the [DRUM KIT] and [SAMPLE] buttons while turning on the power switch.
The display will show "FACTORY RESET OK?"
Press the [DRUM KIT] button to execute the factory reset.
The display will show "INITIALIZING" while the reset is being performed.
When the reset is complete, the display will show "COMPLETED".
Note: Performing a factory reset will delete all user kits, samples, and other custom settings that you have made. Be sure to save any custom kits or settings that you want to keep before performing the reset.
I need to reset galaxy tab 10.1. was my daughter's and she forgot pattern and email/password....nee d to get past the lock screen
hi Jon.
A factory data reset may help with a blank or frozen screen, apps crashing or freezing, keypad/touchscreen problems, can't hear, device making noises, can't make or receive calls, and device won't sync.
Perform a factory data reset only if absolutely necessary as it removes all data including:
  • GoogleTM account
  • System and app data
  • App settings
  • Downloaded apps
  • Media (Music, pictures and videos, etc.)
Notes:
  1. Power the device off.
  2. Press and hold the Volume Up button and then briefly press the Power button to power on the device.
  3. Release the Volume Up button and the Power button when the Samsung logo displays on the screen.
  4. Use the Volume Up button to select the small android with an arrow icon.
  5. Press the Volume down button.
  6. Use the Volume button to select Recovery Console then press the Power button.
  7. From the Recovery Console screen, use the Volume button to select Wipe Data / Factory Reset then press the Power button.
  8. Use the Volume button to select Yes then press the Power button.
  9. Once the Wipe Data / Factory Reset has completed, use the Volume button to select Reboot System Now then press the Power button.
    Allow several minutes for the factory data reset and reboot processes to complete.
    To set up the device after completing the factory data reset, refer to Initial Activation and Setup.
Related Topic: Factory Data Reset
2answers
How do i factory reset my verizon samsung 10 tablet?
To help you perform a factory reset if your Samsung tablet is working and powered ON, please follow the instructions mentioned below:
- It is recommended to back up all the data like Phone contacts, Email accounts, App settings and Downloaded apps, Music-Picture-Videos, Internet browsing data and Personal data from the tablet before performing factory reset.
- From the Home screen, navigate: Apps > Settings > Privacy.
- Click on 'Factory data reset'.
- Click on 'Reset tablet'.
- Click on 'Erase everything'.
- Allow several minutes for the factory data reset and reboot processes to complete.
Now, if in case you need to perform a factory reset if your Samsung tablet is powered OFF, please follow the instructions mentioned below:
- Press and hold the 'Volume Up button' and then briefly press the 'Power button' to power on the device.
- Release the 'Volume Up button' and the 'Power button' when the Samsung logo displays on the screen.
- Use the 'Volume Up button' to select the 'small android with an arrow' icon.
- Press the 'Volume down button'.
- From the Recovery Console screen, use the 'Volume button' to select 'Wipe Data / Factory Reset' then press the 'Power button'.
- Use the 'Volume button' to select 'Yes' then press the 'Power button'.
- Once the Wipe Data / Factory Reset has completed, use the 'Volume button' to select 'Reboot System Now' then press the 'Power button'.
GuruAid.com
I forgot security code to my HTC rezound beats audio phone
Performing a factory reset from settings
  1. From the Home screen, press MENU , and then tap Settings.
  2. Tap Storage > Factory data reset.
  3. Tap Reset phone, and then tap Erase everything.
Performing a factory reset using hardware buttons
If you can't turn HTC Rezound with Beats Audio on or access settings, you can still perform a factory reset by using the hardware buttons on HTC Rezound with Beats Audio.
  1. Remove the battery, wait for a few seconds, then reinsert the battery.
  2. Press and hold the VOLUME DOWN button, and then press and hold the POWER/LOCK button.
  3. Wait for the screen with the three Android images to appear, and then release the POWER/LOCK and VOLUME DOWN buttons.
  4. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER/LOCK button.
Resetting HTC Rezound with Beats Audio
2answers
Zoom R16 factory reset
To perform a factory reset on the Zoom R16 recorder, follow these steps:
  1. Power off the Zoom R16 by pressing and holding the [STOP] button.
  2. While holding down the [STOP] button, press and hold the [REWIND] button and the [PLAY] button.
  3. Continue holding all three buttons for about 5 seconds until the display shows "Factory Reset."
  4. Release all three buttons and the unit will automatically restart and restore all factory settings.
Note: Performing a factory reset will erase all user data and settings, so be sure to back up any important data before proceeding.
1helpful
How to restore HTC One V T320e smartphone
If you can't turn HTC One V on or access settings, you can still perform a factory reset by using the hardware buttons on HTC One V.
1. Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
2. Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
3. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
[img title="unlock HTC ONE V hard reset forgotten password" alt="HTC ONE V hard reset" src="http://www.hard-reset.com/images/htc_one_v_hard_reset.jpg" height="350" width="180">
will remove any applications you've downloaded and installed. Be sure to back up
any data and files you want to keep before you do a factory reset.
1. Slide the Notifications panel open, and then tap Settings.
3. Tap Reset phone, and then tap Erase everything.Performing a factory reset via settings
The most convenient way to do a factory reset is via the settings.
1. From the Home screen, press MENU, and then tap Settings.
2. Tap SD & phone storage > Factory data reset.
HTC One V not responding?
If HTC One V frozen and does not respond when you touch the screen or press the buttons, you can still restart it by press and hold the POWER button for at least 10 seconds, and then release it. HTC One V then restarts.
36helpful
How to format HTC WILDFIRE A33333
Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset
Performing a factory reset via settings:
The most convenient way to do a factory reset is via the phone settings.
From the Home screen, press MENU, then tap Settings.
Scroll down the screen, and then tap Privacy > Factory data reset.
On the Factory data reset screen, tap Reset phone, and then tap Erase everything.
Performing a factory reset using phone buttons:
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.Press VOLUME UP to start the factory reset.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
