factory settings could mean performing a system restore to a previous state of the OS. I'll try to explain how you can perform each one of these methods in the article below.
Restore Factory Settings - System Restore
System Restore is the in-built tool of
Windows XP and Windows Vista that allows you to roll back the registry to a previous state. Note that it only "restores" previous settings for the registry and Windows system files.
You can use system restore to get rid of spyware, but if system restore does not fix your problem, you'll have to resort to either a clean
install of the OS or using your recovery CD/DVDs.
You can read my previous post on
how to restore your computer using the System Restore feature. If system restore is disabled, you can read my post on
how to enable system restore again.
Restore Factory Settings - Recovery CD/DVDs
Most computers come with either a
recovery CD/DVD or a recovery partition that is hidden on the computer. This is true for most HP and Dell machines now these days.
If you have one of these, you can access the recovery from within Windows or during startup.
For HP, you can go to Start, All Programs, HP Tools, and then choose
HP PC System Recovery.
You can also press the
F10 key multiple times during bootup to get access to the recovery console in case Windows is not loading properly.
On Dells, you can access the recovery partition by pressing
Ctrl + F11 immediately after the machine is turned on.
Note that all of your data will be lost on the hard drive. Using a recovery CD is not the same as repairing XP. When you repair Windows XP, all of the system files are replaced with the original ones, but your data and
applications remain intact.
Restore Factory Settings - Clean Install XP
Your last and final option for restoring XP to factory settings is to perform a clean install. This requires having the CD/DVD for the OS. If you only have a hidden recovery partition, you will not be able to perform a clean install.
A clean install basically consists of booting from the original XP CD, deleting all partitions, recreating new partitions, and then installing Windows XP from CD.
It's a fairly straight-forward process and you can read this
excellent tutorial for step by step instructions. Again, it's important to note that you will lose all your data in this process.
It first started when I was installing a printer and a Windows updated rebooted the PC before finished (or other way round) that was all I was doing when it went pear-shaped.
