Question about Blenders
I have a sunbeam blender model #6094 and the blade is discontinued, is there any others that would fit this model? Thanks, Lisa
Stanless steel base my sunbeam blender with the model # 6094 and the blade has been discontinued by sunbeam. Is there any others that will fit this model??
Posted by Lisa Cardiff on
Tom Chichester
    Top Expert:
  • Blenders Master
  • 55,562 Answers
If the blade has been discontinued by Sunbeam, maybe they can suggest a substitute.
Posted on Jan 10, 2014
3 Related Answers
cactus bob
BOB BROWER
  • 267 Answers
SOURCE: blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 24, 2009
Anonymous
SOURCE: Sunbean Blender Liking problem
I have a better than original seal made of a material approved by the FDA. Let me know if you are still interested.
Cheers,
JJ
Posted on Apr 07, 2009
Anonymous
SOURCE: GE Blender Jar loose rotator
Remove the bottom clean the unit fully. Add the bottom blad assebly and this will fix your problem. The "sooty" is plastic shavings. Take note that the fitting were the "jar" connects to the motor that this is not wearing away. The unit i have broke and i am unable to find a replacement blade assembly.
Posted on Aug 13, 2009
Blade assembly broke, the part that fits into the motor and turns the blades.
Dear Vicki,
Fixya does not have any parts for anything.
We are a problem solving service, we answer questions only.
Please tell us your make, model, and serial; number for your blender.
Also, type the manufacturer & model information into your computer search engine, and see who sells part for you in Canada.
Know that some blenders cannot be repaired, unless they are quite old, and then sometimes the parts are no longer available.
God bless your efforts.
May 12, 2016 | Blenders
In the base, when I put the food in the cup, and the blade cup in doesn't fit the base. it appears the the blade doesn't go down in the base. I need help, I don't know if the base
Lots of questions, not a lot of information. Is the rubber sealing washer in the wrong place. I have no idea what model/brand you have but on most blenders the rubber seal will go between the beaker and blade assembly, not the blade assembly and the collar.
Jun 18, 2015 | Blenders
How do I remove old blade?
Hi Paul,
There is a collar on the base of the jar that screws onto the jar. You will need to unscrew the collar and fit a replacement blade. make sure the seal is replaced with the blade and the collar is screwed back securely.
See this link for the parts of the blender.
CUISINART CANADA SmartPower Premier 600 Watt Blender CBT 500C
Also see the product description for the blade.
https://www.youtube.com/watch?v=rdBxUAsT_TQ
Mar 04, 2015 | Cuisinart Replacement Cbt-Bg-1 Blender...
Sunbeam 2774 Blender Logo Problem with the Sunbeam 2774 Blender I need a gasket for my sunbeam blender #2774.
The gasket is not available by itself, you need the blade assembly part number 123250-000-000 available from Sunbeam at 1-800-458-8407.
Aug 13, 2011 | Sunbeam 2774 Blender
Blenders Logo
185 people viewed this question
Top Blenders Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
