Question about Connex CX-3400hp AM/FM 10 Meter Amateur Mobile Transceiver
Converting 10 meter to 11 meter on Connex CX-3400HP CB RADIO
Mike Charette
    Genius:
  • Connex Master
  • 1,847 Answers
Turn the mode switch to the setting you want and leave it there .
Posted on Oct 03, 2018
3 Related Answers
kb8dns
Rod Wallberg
  • 494 Answers
SOURCE: i just purchased a connex 3400hp and my cb freinds
The Cobra 29 has always been a good talking radio and is preferred by truck driver mainly for that reason! The Connex is a great radio in it's own right but sometimes needs a little help. I would suggest a power mic and there are many to choose from but Astatic is a clear winner! My two cents for a suggestion!
Posted on Mar 07, 2010
anymhz
AnyMHz.com
  • 500 Answers
SOURCE: how to convert a connex
That needs to be done by someone that knows how, theres soldering involved. most cb shops will do it for $free-$10.00... Don't pay any more than that.. there are no parts nor is it hard so they shouldn't charge much.
Posted on Mar 01, 2011
Bigfoot350
  • 6 Answers
SOURCE: I have a connex cx-3400HP d and a r not working until the unit get's hot
Take it to a good cb shop radioactiveradios do really good work on connex radios
Posted on Jun 06, 2012
Connex 3400 hp makes static noise when I hit bumps in road.
don't hit any more bumps. The problem could be in several areas. I'm going to say that you may have a loose capacitor inside If I had the radio here I could fix it but because the problem may be so spread it could be a lot of things Are you a truck driver? If you are take it to a CB shop at one of the many truck stops and see if they can fix it for you .
Jan 22, 2016 | Connex CX-3400hp AM/FM 10 Meter Amateur...
Why does the red light for antenna stay on
This means that your swr is high. you can damage the radio using it in this condition, check antenna and coax for damage or misinstallation
Feb 27, 2014 | Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt...
I have a connex cx-3600hp cb and it sounds like it has no power
your power switch it faulty as there is a drop in voltage
does the meters dim down?? then the voltage supply past the power switch it dropping as it draws more current or... the audio ic has damage or one of its associated capactors sometimes a diode can become leeky its used for AM modulation also
Feb 25, 2014 | Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt...
I have a Connex 3400 Hp and it stopped receiving all of a sudden while driving down the road and the needle on my meter is dead on 0. I've doubled check to make sure all my knobs and switches we're in the...
check for a fuse bulb for the RX section i would have a radio engineer look at it as you smell stuff
its also not a good idea to drive around with known faulty electronics in your car its a bad problem just waiting too blow up in your face... so.. dont leave electrical issue in cars your family depends on
Feb 16, 2014 | Connex CX-3400hp AM/FM 10 Meter Amateur...
May 27, 2012 | Connex CX-4300HP CB Radio
Fix my connex 3400 hb sideband button
Hi there, if you are talking about the Connex CX 3400 HP there is no sideband or SSB on this radio. It is only AM and FM 10 meter Ham radio. Many people do modify these radios to include the 11 meter frequencies which is the CB band. Maybe knowing the actual bands and their frequencies will help some too this radio does have 6 different bands ranging from (Band A. 28.015 thru 28.455) (Band B. 28.145 thru 28.585) (Band C. 28.115 thru 28.555) (Band D. 28.085 thru 28.525) (Band E. 28.055 thru 28.495) (Band F. 28.025 thru 28.465.) I hope this will help you. Bob
May 13, 2012 | Connex CX-3400hp AM/FM 10 Meter Amateur...
I just purchased a connex 3400hp and my cb freinds tell me that my other radio sounds better than the cx 3400hp,my other radio is a cobra 29 ltd classic.my 29 has more audio and modulation and both radios...
Mar 07, 2010 | Connex 3300 240-Channels Base CB Radio
My friend would like to purchase a Connex CX 3400 HP. The store told him that it has to be converted to a CB radio. But they can't do it because its illegal. Can you explain this to me?
These radios are know as what's called 'export' radios. They are imported under the auspices of being a 10 Meter Amateur radio and then through a typically easy modification are made to allow the selection of US CB channels. usually the modification involves plugging in a loose connector inside the radio radio chassis and/or removing a jumper wire soldered to a circuit board. If there is a nearby CB Shop they will usually do this for a modest fee.
Keep in mind that a radio needs to be Type Accepted by the FCC to be legal to use on the CB band in the US and export radios typically are not. Be sure to check the rear label for an FCC ID number.
Feb 12, 2010 | Connex 3300 240-Channels Base CB Radio
10 meter portable
There is no factory made 10 meter CB Radio made for US use. CB Radios use 11 meters, and the FCC doesn't allow the combination of 10 and 11 meter radios combines. Although, many people modify 10 meter radios to work on the 11 meter ( CB ) band, it's not legal. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 15, 2007 | Magnum 257 CB Radio
Connex CX-3400hp AM/FM 10 Meter Amateur Mobile Transceiver Logo
291 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
