Question about Intel D845GVSR Motherboard
Smsc Lpc47m133 Nc Ibm Audio Driver - Intel D845GVSR Motherboard
1 Related Answer
computus
Tony Rose
  • 487 Answers
SOURCE: lpc47m133-nc audio driver
Hi, try this link: http://en.kioskea.net/download/motherboard-drivers-151
Hope this helps
Posted on Jul 08, 2010
My computer starts, but empty screen
Sounds like you need to install a display driver.
Mar 08, 2013 | Computers & Internet
I need a audio driver for my computer
Download REALTEK PHRE10/100PCI ETH RJ45 100MB nc-r150201 Network Adapter Drivers
  • http://www.free-4all-download.com/REALTEK/REALTEK+PHRE10/100PCI+ETH+RJ45+100MB+nc-r150201+Network+Adapter+download
  • http://www.softitem.com/driver-intel-realtek-phre10-100pci-eth-rj45-100mb-network-adapter-frequently-asked-ques
  • http://www.alldriversfree.com/013/drv/realtek-phre10-100pci-eth-rj45-100mb-nc-r150201-network-adapter
Sep 19, 2011 | Intel REALTEK nc-r150201 Network Adapter
Hp nc 6220 audio driver using window vista business
log in to WWW.Microsoft.comand type download hp nc 6220 driver on the search text box.
click search
select the type of operating system e.g VISTA
begin to download
Aug 29, 2011 | HP Compaq nc6220 Notebook
Smsc chipset needed driver
Always get your drivers and specific software from the manufacturer of your Laptop, Notebook or Desktop. They are usually free of charge.
If you were to log on to the www.ibm.com web site, usually one is able to download if available, by model number, All available Driver downloads as required.
If the driver is not available, perhaps your manufacturer does not support the OS you are installing.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
Mar 21, 2011 | IBM Netvista Intel Pentium 4 2.4GHz /...
Lpc47m133-nc audio driver
Hope this helps
Jul 08, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
I think i have a smsc motherboard Dell computer.. I need an audio driver
hi, just check and write i ic audio chips number and search it to the internet the compatibility driver for that chips... download and then install it...
regards
Mar 05, 2010 | Intel Motherboard
My laptop sound is not wrcking
www.opendrivers.com/driver/233753/ibm-thinkpad-r50e-audio-driver-v5.12.01.5410-windows-2000-xp-free-download.html
www.soft32download.com/software/IBM-ThinkPad-R50e-Audio-driver-download-details.html
try the above two links where you can download the driver
Aug 04, 2009 | IBM ThinkPad R50e Notebook
Intel D845GVSR Motherboard Logo
540 people viewed this question
Top Intel Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
