Question about Konica Minolta bizhub C351 All-In-One Laser Printer
C35 error code c0203 - Konica Minolta bizhub C351 All-In-One Laser Printer
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
Which is it c35 or c351
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jun 27, 2016
1 Related Answer
iftikharhmd40
  • 229 Answers
SOURCE: how to c35 chip cencer error disbled than running for machine
Re: error code 0094 on a Konica Minolta C35
Make sure the second transfer release solenoid isn't hanging up due to the pad that's there to minimize noise. See the attached pic. This pad had gotten sticky enough that it was delaying the action of the solenoid. Took a lot of service calls to figure this out!
paperclip.png Attached images
Posted on Oct 30, 2014
My minolta bizhub c6501 has a trouble code of c0203. How do I fix it?
Description
Intermittent C-0201 (C0201), C-0202 (C0202) and C-0203 (C0203)paper lift error codes.
Solution
PROBABLE CAUSES:
1.The trail edge paper guide (p/n A03U R756 00) may not be pressed against the paper. This will allow the paper to fall backwards and induce the error code.
Instruct the end user to check the position of the trail edge paper guide whenever paper is loaded into the paper tray.
2. Coupling for the tray lift for Tray 1, Tray 2 or Tray 3 is obstructed or out of alignment causing the tray to not lift.
Inspect the coupler in the back of the machine for paper preventing the pin from seating in the coupler. Check alignment when tray is inserted. If out of
alignment try to adjust the drive to properly align.
Oct 04, 2017 | Minolta Office Equipment & Supplies
Pls help on how to clear error 0310 on bizhub c20 i have checked all the connection and my print head is ok what next shuld i do to remove this error pls is very urgent thanksa
You didn't say what make of printer it is. Error codes vary from printer make to printer make. Your best bet is to do a Google search for ERROR CODE 0310 NAME (NAME=name of printer).
If It's a Konica Minolta read the link below:
Konica Minolta Bizhub C35 Error Codes
Feb 17, 2016 | Office Equipment & Supplies
How do i fix error code 13DD ON KONICA MINOLTA BIZHUB C35
The counter data on one card does not match counter data on a different board did some one try to reset the counters to make the machine newer???? Need to get tech out to try and rewrite the firmware,
Jun 30, 2015 | Konica Minolta Bizhub C35 Multifunction...
How to c35 chip cencer error disbled than running for machine
Oct 29, 2014 | Konica Minolta Office Equipment & Supplies
Bizhub C35 error code 0F54
Cyan (Blue) Toner level sensor error, using OEM toner???? or third party?
Jan 31, 2014 | Konica Minolta bizhub Office Equipment &...
Error code c0203
What model of machine is this code on ?
Dec 14, 2013 | Minolta Office Equipment & Supplies
Error codes 0241-750050
If you are talking about windows updates, then you can download a hotfix from microsoft from here
Nov 23, 2012 | Computers & Internet
Error code c0203
What machine? sir/mam
Apr 03, 2012 | Minolta Office Equipment & Supplies
Bizhub C35 misfeed error
This video will show some of the most common causes for Bizhub C35 misfeeds
https://www.youtube.com/watch?v=Sbo0gon8EIY
I’m happy to help further over the phone at https://www.6ya.com/expert/mark_3d8ef710fe85c567
Feb 26, 2012 | Konica Minolta bizhub C351 All-In-One...
HI, Does anyone know a clearance for a Konica Minolta Bizhub C35 with error code 0F52, thanks
Yellow Toner Sensor malfunction. Check connectors on PRCB, inspect/disassemble/reassemble/reinspect yellow toner sensor assembly, or possibly replace PRCB.
Source: service manual.
Credentials: I am having this same code right now.
Feb 17, 2012 | Office Equipment & Supplies
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
93 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
