Sparkle Power FSP300-60BT (FSP300-60BT)) 300-Watt Power Supply Logo
A
Anonymous Posted on Jan 10, 2014
Common Issues with Sparkle Power FSP300-60BT - Sparkle Power FSP300-60BT (FSP300-60BT)) 300-Watt Power Supply
What is the value of R61 resistor
It's not worth enough to warrant you risking your life to replace it. Especially on that piece of garbage PSU. You can die if you try fixing a power supply and touch the wrong thing inside. Seriously.
When I attempt to boot up the PC with the Sparkle 460 GTX 1gb gfx card, the bios screen will not show all the words printed out, instead with a long white box sometimes, sometimes its fine. When Windows is...
In that case the graphics card that u have mentioned might be faulty. Try downloading the latest the update for the graphics card from the manufacturer's website and check. If the same issue remains then the graphics card is faulty.
1helpful
Can I Run A GTX 260 on my Intex Accopia 600w PSU? Is it True Rated? Here are my specs: Pentium D( Upgrading soon to Q8400 ) 1gb ram 80gb HDD ( Upgrading soon to 500gb ) GTX 260 ''Not installed'' ( Waiting...
if the power supply has the 6 pin connector to plug into the video card, you should have no problem using this card with your current setup..
i currently use a GeForce 9800GTX+ with about the same pc as you have using a 600w power supply and no issues what so ever, generally the video card power supply requirements will be stated on the side, but i'm pretty but it requires a 450w or 500w, so you should be fine.
After 5 min. screen blanks out then on two or three times then goes blank completely to standby mode
Sir,
To me it seem the Driver setting of Card or the power managment problem of you Computer. You are suggested to click on control panel and there go on to power management then do all the Power options to "NEVER" option in them. this might fix your problem
Video card not installing
Did you make sure you uninstalled the original 9600gt driver, other than that you could try safe mode with networking and download/install the driver.
1helpful
No power up
You need to locate the PS_ON pin and short to ground (GND). This pin may vary depending on model and I don't know if green is the standard color for this, but it is green on the unit I just looked at for reference and it it aso shown here http://pinouts.ru/Power/atx_v2_pinout.shtml
any black wire should be ground
NO Signal
I suspect that your power supply may have overheated if its fan is not working properly try another power supply
Schematics forpower supply
Go to this site: http://pinouts.ru/pin_Power.shtml.
It should have the pinout info you need. If you're intending to fix the unit, you can get a replacement (with more power) at this site for less than $20, including shipping: http://www.geeks.com/.
Top Sparkle Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Sparkle Computer and Internet Expert? Answer questions, earn points and help others
