How to take it out of standby mode
SOURCE: Red stand by light blinking
5 blinks = lamp driver (ballast) failure.
1-468-798-14 for the 610 model
replacement is done from the back of the set, should be straight forward, keep the red ballast wires apart for best results
if a tech replaced the red tube, you have an older tv where 5 blinks is the AKB error meaning your CRTs are getting old.
SOURCE: set wont turn on, stand by lights blinks 9 times
Have the same thing happening with ours... we were told by a repairman that it needs a new D Board. He told us that if we could fix the TV for under $500 that it was worth it, if not (which of course, we can't when you add in labor cost) don't fix it. I like the TV but I can buy a brand new flat screen for that!
Good Luck
SOURCE: the standby light blinks green like its about to
A very common problem in Grand WEGA, In short the solution is, The LAMP needs replacement. Replace the lame and it will work fine again.
Thanks.
SOURCE: timer standby mode light blinks red? tv wont turn
Power supply board it dead,must replaced the power supply board to get the power back.Tries Shopjimmy.com,Ebay.com to buy the refurbish power supply.
