I have removed the print job from the computer, cleared all printer memory, turned it off and on again a billion times and it is still stuck on the "PC Print pending" it won't print anything else or copy it's just stuck!! please help!!
SOURCE: samsung scx-4521f fax memory received but never print out.
In 3 second make combination on you Samsung 4521F 'Menu'-#-1-9-3-4. You will enter in tech menu. Select 'toner'-new toner-yes. You will receive faxes. It really works.
SOURCE: problem scanning with samsung scx 4521f
My connection is via a parallel to parallel cable, and I am also having a similar problem. I'm reading that usb to usb cable is the only way it will properly function. good luck with it!
SOURCE: PC Print Pending Message Won't Go Away
Have you tried to delete the print job from the computer? After that is done reset the printer by turning it off (30 sec) then on again. If that doesn't work take the paper out and start cleaning your printer with canned air, Q-tips and a cap full of water.
SOURCE: printer won't print
mac OS X 10.5.5 update disabled some printers. you have to reconfigure the printer on your computer
SOURCE: Samsung SCX-5421F Laster Printer crashes my pc
Have you tried uninstalling and re-installing the software. Perhaps there is an updated driver for your system since you first installed it, or maybe yours is simply corrupted. I would suggest removing and reinstalling will solve the problem - if, in fact, that is your problem -I've not heard of this happening before.
Drivers are here if you need them:
http://www.samsung.com/ca/support/download/supportDown.do?group=printermultifunction&type=printermultifunction&subtype=monochromemultifunction&model_nm=SCX-4521F&disp_nm=SCX-4521F&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010300&model_cd=&menu=download
