Radio Shack 43-338 2-line Dect 6.0 Cordless Phone 2 Handsets Answering Machine Logo
A
Anonymous Posted on Mar 02, 2018
Line 1 has constant dial tone, cannot call out or answer calls.
Line 1 is a constant dial tone. Cannot call out or answer phone. Line 2 works fine. Not sure what to check to troubleshoot this problem. We have another phone that picks up Line 1 just fine but not sure what happened to the RadioShack handsets that line 1 does not connect anymore.
1 Related Answer
Anonymous
  • 2777 Answers
  • Posted on Nov 02, 2010
SOURCE: Since my husband died, no
Is this a standalone answering machine or a phone with answering machine built in? Are you certain that is the catalog number and there is no other reference to a model number? That number does not pull anything up, but it's possible you are correct, just want to verify.
Please let me know a little more info there as asked and I will be glad to help you here. Please just reply to my answer here and we will keep going at it!
Thanks
Tim
Why no dial tone??
have you plugged your new phones telephone line into the telephone socket?
4answers
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
No dial tone on line 2
CALL THE COMPANY OF THE PHONE OR CALL THE PHONE COMPANY THAT PROVIDES THE SERVCE OF YOUR PHONE
I just installed a replacement At&t EP 5962 2 line, answering answering device telephone. Line 2 does not get a dial tone. I installed it into proper / same as before outlets and both lines light...
There may be damage to the wiring of line 2 (either in the building or on the phone). Are both lines wired to one jack or are they separate? Do you have any other jacks that have line 2 connected (preferably as single line jack) in the building?
I like to use an old single line corded phone that does not use a power adapter. (As long as the EP5962 corded base will work without power (POTS), it might work for the tests below. You might want a simpler phone to carry around.)
If the lines have separate jacks, try switching line 1 and line 2. (Connect your Line 2 jack to the Line 1 input on the phone and vice versa.) If line 2 doesn't give a dial tone when connected to line 1, see the next set of tests. Otherwise, contact AT&T if the phone is under warranty. These phones are not meant to be user-serviced. Alternatively, plug in a different phone to the line 2 jack to test for dial tone.
Next move to another jack with line 2. Check if you have dial tone at that point. (If you do, you know the problem is at the first jack or the wiring to the jack.)
If there is no dial tone at the next jack or you do not have another jack for the line, find where your telephone service comes in. Open the service box and determine the type of connections in the box. If you are lucky, you will find RJ-11 jacks for the incoming service. Plug in your test phone and check for dial tone. If you have no dial tone or can't check the service, then contact your telephone company. They will test your line and fix it free if the probIem is outside.
If you have a dial tone, then it's an inside wiring problem. Inspect the visible wires for damage. Open the faceplates for the jacks and check for loose wires. There are two types of connectors. Screw type connectors need the wire stripped back a little then wrap around the screw and tighten. The other type is a punchdown jack. To repair a loose wire in this, you will need a punchdown tool. These are often available in hardware/home improvement stores in the wiring section. http://www.lanshack.com/wire_phone_jack.aspx has clear pictures of the wire color to pin pattern.
You may want a professional to check the wires inside the walls. Your phone company will fix problems for a fee.
Damaged DSL filters on one line could be the cause. Similarly certain animals may have chewed on the specific wires somewhere in the line.
I hope this helps.
We have a 4-line system in our office, but it is not working properly. For instant, when line 4 rings...it only comes into one of the phones. All lines are working properly with dial tones. If we would...
Now here's a conflict. Does line 4 work on any other phone where it doesn't ring? You say all lines are working properly wiith dial tones, tnen you say you can't pick it up from another phone.
I don't think these phones have "private lines", but the dial tone comes from the 2nd RJ-14 jack on the wall. On every phone, you could swap the plugs so that line 1 comes into line 3 and line 3 comes into line 1 (you'll lose the intercom) and see if you get dial tone on line 2 which will be the phone that works line 4. The point being to determine if you have a wiring issue or a programming problem.
Carl
2answers
How to program speed dial on T7208 telephone?
Programming
memory buttons
External autodial
1. If you are on a call or an open line with dial tone, press Hold
or Rls
2. Press Feature * 1
3. Press a memory button.
4. Dial the external number.
5. Press Hold to store the number.
6. Label your new button.
Internal autodial
or Rls
2. Press Feature * 2
4. Dial the internal number.
5. Label your new button.
Features
or Rls
2. Press Feature * 3
4. Press Feature and the feature code.
Erasing memory buttons
or Rls
3. Press the memory button you want to erase.
4. Press Hold to erase the button.
2answers
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Faxing problem
1) Plug a single line wired (not cordless) phone in to the exact same phone jack as the fax machine and dial one of the fax numbers you are trying to dial out to using the exact same digits. Does the call complete Y/N? do you hear a fax tone Y/N?
>>>>If either answer is "No" you have an invalid phone number. If both answers are "Yes" proceed to step 2.
2) When you off hook do you hear a "stutter" dial tone? Y/N?
>>>>>"Yes" This is your phone company telling you that you have unlistened voicemail messages in your mailbox. Dial in to your voice mail and clear your messages. "No" go to step 3.
3) 2 part question: Do you have call waiting and is your fax machine trying to disable call waiting when dialing out?
>>>>>In many areas *70 (star-seven-zero) will disable call waiting for a single phone call. If you try to disable call waiting when call waiting is not on the line, the call will not complete. This may come in to play in a speed dial situation.
+++Other things to consider+++
*Is outgoing long distance blocked on the line?
*Is outgoing regional intralata (same area code) long distance blocked?
*Is local calling blocked?
*Is a speed dial misprogrammed? Forgot to dial "1" Dialed "1" in error?
*Is there a wiring problem? >>>Try moving fax machine to a different phone jack.
There may be no magic answer for your problem, I hope one of these suggestions helps.
7answers
How to switch phone to tone
I found a manual from AT&T that had the information I needed. Thanks!
Top Radio Shack Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Radio Shack Lands Phone Expert? Answer questions, earn points and help others
