Question about SanDisk Sansa e260 MP3 Player
My Sansa e260R will not work. When I go in to my music and I click artists or my playlists or my songs the screen will have bars and it will change colors. Then if I try to do anything it is frozen! I tried to refresh my database by putting my hold button on hold. Then I held the record button and plugged my USB cable into my computer and then into my MP3 player. IT WON'T WORK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ThaMp3Doctor
  • 8,597 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
Load music on my ipod
Connect your iPod to your computer with the USB cable that came with your iPod. The iPod screen should say "Do not disconnect".
Your iPod should appear under Devices in the bar to the left.
Decide whether you want to sync your iPod with your iTunes library or manually put songs on your iPod.(nano only)
Syncing your iPod will automatically add all of the songs in your library to your iPod. It will also delete any songs from your iPod that are not in your library. Click on your iPod icon and select Sync in the lower right corner.
If you do not want all the songs in your library on your iPod, make a playlist of all the songs you do want, or decide which playlists you want to include on your iPod.
On the top bar, click on the button which says "Music"
Make sure the box that says "Sync Music" is checked, then check the box for whether you want your iPod to sync with the entire library or selected playlists. If you click selected playlists, select the playlists you want in the playlists category. For newer iPods you can check which artists are included on your iPod to automatically import all the songs from each selected artist onto your iPod
Mar 21, 2011 | Apple iPod nano
Plays six of twenty mp3s and the rest come up as
Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete
Labeling Unknown Songs: open Windows Media Player and go to library click on artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... This change in your computers Music folders also then sync with your sansa or media player then load songs to it........
Jul 27, 2010 | SanDisk Sansa e250 MP3 Player
MP3 FILES LISTED AS UNKNOWN
Labeling Unkown Songs: open Windows Media Player and go to libary click on artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... This change in your computers Music folders also then syc with your sansa or media player then load songs to it........
Apr 08, 2010 | SanDisk Sansa e260 MP3 Player
How to delete songs
There's no way of directly deleting a song on the player. You need to do it either via Windows Explorer, or a music manager program which "syncs" to your player.
To delete a song via Windows Explorer, connect your Sansa to your PC, open up "My Computer" (or "Computer" if you're running Vista), and you should see your Sansa listed there. Double-click on it. If you then see "Internal Memory", double-click on that. You should then see a list of folders including "Music". Double-click on that, and you should see a list of songs. If you see a list of folders named after your Artists, double-click on the appropriate Artist folders to find the songs you want to delete. Select the song(s) and press "delete" on your keyboard.
If you use a music manager program such as Windows Media Player, Media Monkey or Winamp to sync music onto your Sansa, just delete the song from the music manager library or playlist(s) you're syncing to your Sansa, then do another sync.
Feb 17, 2010 | SanDisk Sansa e200 MP3 Player
Deleting songs , how do you delete songs off the ipod touch?
connect it to itunes.. click on the ipod and under the music tab.. uncheck sync all music from music library
Dec 22, 2009 | Apple iPod touch
I can't add new music folders to my sansa e260 because some go to
open windows media player and goto libary click on album artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... then syc with your sansa then load songs to it........
Mar 24, 2009 | SanDisk Sansa e260 MP3 Player
How do you create a playlist?
Solution 1 In the Sansa drive in Windows Explorer select the songs that you want in the playlist. Right click and create playlist. You can do minimal playlist editing through the playlist file properties. Drag files to the references tab to add files.
There is a free playlist creator which creates playlists for each folder on the sansa player with one click. it is written in .NET and does not alter the music files (http://www.infosys.tuwien.ac.at/staff/cp/playlist_creator.zip).
There is also one written in Python that should work on both linux and Windows (http://people.ifm.liu.se/yohell/make_playlists.py).
Solution 2 Try Musicmatch Jukebox or MediaMonkey. Both of those should be able to create a music library using only files from the device. Then sort them by artist and album, and delete them from the library, deleting the files as well. Transfer new files to the device as files (MSC USB mode on the player), not by syncing. You can create a new music library on the fly if you've made extensive changes. It doesn't take much time. Playlists should not contain drive letters or folder names, so edit them in Notepad, unless you have an app that makes them on the fly (suggestions?).
You can keep your main database in MediaMonkey, and open the Sansa device (see the plus and click on it). You'll be able to delete files from there. But if you double click on a song on the Sansa device, the wrong song will play. Dunno why, but that's what happens on my computer. But deleting files works.
Solution 3 Rename all your tracks so artist (look for batch renaming feature in your software. Add example of freeware editor?), album and song name is in the file name. That won't be visible in the player, but can aid administration if you use the player in MSC mode.
Solution 4 A how-to for using Windows Media Player and syncing to make playlists can be found here.
added by thatsRich 04-08-06 - I was having trouble sorting on my Sansa m250 using drag and drop with basic file management for mp3s. After seeing this article, I tried Windows Media Player (version 10) and found that perfect for the job. Since you can drag mis-sorted files in the left pane, they "sync" in proper order.
Jan 20, 2009 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa e260r
Open Windows Media Player with the Sansa connected.
Open the Songs folder that is underneath the icon of the sansa player. Left-click a song, and hit the Delete button on your computer's keyboard.
Mar 21, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
313 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
