Arcsoft ShowBiz DVD 2 (3265) Logo
A
Anonymous Posted on Jan 09, 2014
Audio doesn't play
After creating my file, I play the movie but no audio is heard.
I buy LG 32LM3410, when i play movies through USB suddenly it plays with no sound, at first it has sound but after a while no sounds will be heard.
I also encountered the same with my 32LM3410 problem with the AAC audio, and it will affect all the succeeding plays until you have to restart the TV. Need to have the file audio converted to AC3 (Dolby Digital) for smooth playback. I use Bigasoft and mkvmerge to solve the problem. Hope this will help.
tip
Watch/Enjoy Joined Panasonic HS900 MTS Video on Asus O!Play in Full HD 1080p...
Enjoy Full HD Video on O!Play-Combine HS900 MTS into one file without conversion for playing on Asus O!Play
These days many of us have a constantly growing media library, with our favorite music, movies, and photos in a variety of formats and locations. The ASUS O!Play is designed to easily bring your media into your living room, without sacrificing quality. Enjoy video in full HD 1080p resolution,full-fidelity audio, and photo slideshows on your HDTV or home theater setup. With impressively wide format support, a wealth of connection options, and playback over a network or directly from USB and eSATA drives, the O!Play is an elegant and modern media solution. Such a cool HD media player supports formats include full hd 1080p mts.
If you are interested in recording with HD camcorder, like Panasonic HDC-HS900 which give MTS extension, you can directly Transfer and Enjoy Panasonic MTS files to Asus O!Play via HDMI. However, before enjoy them with O!Play, you may want to do simply editing like cutting off unwanted or unimportant parts and then merge or join the trimmed MTS files into 1 file while keeping the same format, without losing any quality. Sometimes you can also put them in a format for devices to watch anywhere in the house or on the go.
Now I will show you a fast way to Cut off Panasonic HS900 MTS clips, and then Combine HS900 MTS into one file without conversion for playing on Asus O!Play with Full HD 1080p resolution.
Step 1. Capture MTS from Panasonic HDC-HS900 AVCHD camcorder to Aunsoft Final Mate for Mac.
Free Download and Run Aunsoft Final Mate for Mac as the fast MTS Cutter/Joiner without Conversion, and use USB cable to connect your Camcorder to PC. Then follow the camcorder wizard to import videos. After selecting the Import option, you will face the window like below to choose the video clips for importing to Aunsoft Final Mate for Mac. The videos would be listed on the "Camcorder" tab.
Step 2: Create a Movie for Cutting and Joining Panasonic HDC-HS900 MTS clips.
Click the Add movie button, and choose the" For Lossless Output", a movie about cut mts for lossless output will be created by default. Then select one or multiple mts video files you would like to split/join from the Camcorder tab and then drag and drop them to Movie tab. In this way, a Movie for no re-encoding will be created.
Step 3. Split or cut off unwanted parts from HS900 MTS movie for Asus O!Play.
From the timeline, you may notice the vernier, which is used as time pointer. Click on the Vernier, and move to the timeline you want to cut, and click the Split button to cut the video. Then select the unwanted or unimportant parts and click Delete.
To change video sequences, just click on the video clip on timeline, drag and drop to the left or right for the position as you like. One movie will be exported as one file with Aunsoft Final Mate for Mac.
Step 4. Merge/Join/Combine HS900 MTS without Conversion for Asus O!Play.
Click the Export button and choose lossless output, the HS900 MTS cutter/merger for Asus O!Play will start joining large .mts files into one mts file without conversion at the fast speed. The non-conversion process will prevent loss of quality when joining MTS files for Asus O!Play with 1080p.
After a few seconds, then connect the lossless output mts format with Asus O!Play via USB. By Connecting the O!Play HD Media Player via HDMI with HDTV , you can Enjoy full 1080p high-definition video and digital audio output for lossless audio transfer to your receiver or TV.
Tips:
If you think that MTS file is so large that can't play smoothly on O!Play, you can also use this program to convert MTS file to MP4, AVI, MOV, WMV, etc with smaller size for Asus O!Play.
2answers
I can not play movies in my totem movie player, AMR is missing
Hi..
AMR (Adaptive Multi Rate) is common audio file format for mobile devices like mobile phones, laptops, portable recorders.. etc.
in fact totem movie player can't play any amr files (files encoded in amr codec) by itself. Totem Player depends on Gstreamer libs, which haves necessary media handling components .
from your post its not clear that whether your totem can't play movie files from the very beginning or just you can not play movies recently.
your totem player may lacks Gstreamer library files or somehow your Gstreamer libs got corrupted recently.
Reinstalling Gstreamer Library file may help you.
you can find latest source version of Gstreamer on this page
(more detailed download of Gstreamer can be found on http://openports.se/multimedia/gstreamer-0.10 )
2answers
How do I create a playlist to play different kinds of music instead of my music being alphabetical
the device software that came with it should have an option under edit or file where it says create new playlist. however if it doesn't you can use winamp free from winamp.com to create one
2answers
I have prepared a home movie on Windows Movie Maker and when I copied it to a DVD it would not play on a dvd player can anyone tell me what I did wrong please thanks joe
The reason why the DVD disk you created may not contain the file format the DVD player recognizes. On a normal DVD disk there are two folders - AUDIO_TS and VIDEO_TS folders. The video files are located in the VIDEO_TS folder. This video folder contains the VTS_xxx.vob video files (the video files has a .vob extension).
The video file you created may have a avi or wmv or mov or mpg extension, whilst these video files can be played on a computer but they won't play on a DVD player.
Check the movie software you are using and make sure it creates the correct file format for a DVD player.
2answers
Will only play certain xvid.avi files but not all...
you will not be able to do so. every mp3 player,ipod,phone has its own file formats. you will have to convert it in to the format which are supported by your lomega screenplay.
THANK YOU
2answers
Audio won't work on my movies!!
For most iPod owners, include you I guess, are not satisfying with only to play common music and videos with your lovely iPod. While there has been many times I heard that people complaining about the issues that some songs not playing with their iPod touch, more specifically, the iTune plays the music, seems to sync and the album cover shows up, but when trying to play it on iPod, the track doesn't play and the progress bar doesn’t move. Some just say that some certain video files can’t play on their iPod. All the problems could be caused by compatibility issue.
There’s a way out. With the help of additional freeware and shareware apps, it's easy to extend your 'iPod's abilities in more ways. iPod video converter is definitely a good choice . Being powerful but easy to use, it enables you to convert all popular audio and video files, such as AVI, MPEG, MOV, MP4, VOB, DivX, XviD, AAC, AC3, MP3 to MPEc,G 4 and H.264 Video that can be playable on iPod family: iPod Touch, iPod Video Nano and of course the new iPod Classic. it also has excellent video editing ability: crop out unwanted subtitles and unnecessary black bars, trim the video by setting the start time and ending time, customize the effect like saturation, contrast, etc,. you can also capture view from the video and store them as jpg,bmp or png.
iPod video converter is suitable for both novice and expert, you don’t have to have previous experience, and you will find just how powerful this program could be .it’s known for fast conversion speed but without video quality loss. Find more specific tools you need to work with your iPod.
1helpful
3answers
Video SLideshow
If you want to create a slideshow, you try ApowerShow. This is an intuitive program that can help you create a slideshow in just few seconds. Try it here : ApowerShow easy video creator to make your great videos in minutes
How to create link from a button to play video
Put a button on your scene, and give it the instance name but in the Property Panel. Create a new layer in your movie and name it code Now add this code to the first frame of the code layer: but.onPress = function () { _root.createEmptyMovieClip("container", 1); loadMovie("loaded.swf", "container"); container._x = 150 ; container._y = 20 ; }
Top Arcsoft Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Robbie Goodwin
Are you an Arcsoft Computer and Internet Expert? Answer questions, earn points and help others
