When I use my automatic feeder to fax or copy it is leaving a thick black line on the right side of the paper. I went through the machine clean and roller cleaning steps to no avail. What is the problem?
SOURCE: canon pixma mp780 - vertical line on printing
Not sure if this will help but there is a small glass panel to the left of your flatbed scanner- this must be clean or else I get a black vertical line in my printing.
SOURCE: thin black lines (mp 530)
Here's the link for how to clean the unit... I was going to post the instructions here, but there are pictures that might be helpful to you.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
Before doing anything more drastic, I would try this.. let us know how it turns out.. if it doesn't work, we'll go from there.
Maggie B
SOURCE: top feeder not working MF6550
One or both of the ADF hinges are bad. The ADF cover doesn't close all of the way causing feed failure of the original and shading on the side of the copy because the scanned original is not fully contacting the **** exposure glass on the front operators side.
SOURCE: Line appears on copies when using the automatic feeder.
You have a piece of dirt or whiteout on the scanner glass. When the paper is moving by, it creates a "Line" if the paper is sitting still on the glass, it may be a dot or it may even use a different glass alltogether for ADF vs Paltten scanning.
