Question about Azpen A9 Android Tablet
How do I get Tablet fix it will not charge?
My Tablet will not charge
Posted by Karen Lowe on
Jeff Henager
    New Friend:
The mini USB cable that came with my tablet was lame and would only charge if held at a certain angle. Another cable worked fine. This is an ultra cheap tablet, and they cut corners everywhere they could.
Posted on Apr 12, 2014
Port on 10 inch tablet not working can it be fix
Linda, if it is the charge port, mini USB, yes they can be fixed or replaced by cell phone/computer repair shop.
Check the attached links videos showing port replacement. Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
Toshiba Tablet AT300SE AT305SE Charging Port Repair
Samsung Galaxy Tablet 10 1 Tab 3 10 1 P5200 P5210 Micro USB Port Replace HD
May 03, 2016 | Tablets & eReaders
The charger wont go in to the port to charge it and the tablet needs to be charged it was working just fine last night dont know if my son did something or not
Robin, the charge ports can be changed at a computer or cell phone repair facility. Check the attached links,instruction and guides, Good luck
How to replace the fixed charging port
How to Fix Tablet Charger Port
Amazon com 2 pcs Replacement Micro USB Charging Port Connector for Vizio...
Apr 24, 2016 | Tablets & eReaders
Unable to charge tablet. Used several different cable. Red charging light only blinks maybe.
You may have to get it fixed. The same thing happened to me before. And I got it fixed.
Jul 26, 2014 | Amazon Kindle Fire HD
7" touch andoid tablet won't charge
It may be the charger has a loose wire. In that case a new charger would fix the problem. Mine has a problem with the charging port itself. I am fortunatly that my tablet is under warrenty they are going to replace the tablet for me.
Dec 27, 2012 | Nextbook Premium 7 Capacitive Touch...
Azpen A9 Android Tablet Logo
758 people viewed this question
Top Azpen Tablets & eReaders Experts
Jim Pattison
 Mikey
Mikey
ray gallant
Are you an Azpen Tablet and eReader Expert? Answer questions, earn points and help others
