Question about Panasonic Lands Phones
Panasonic KX-7431 Call limited to 60 minutes
We have the Panasonic KX-7431 phones in our office. The phone hangs up the call after 60 minutes. This has proved to be rather annoying and I hope someone can help me turn this feature off. Thanks
Posted by Patti Bowles on
Bill Gibbs Sr.
  • 3 Answers
A year later. I looked at the manual for your model phone and didn't see any reference to adjusting the time a handset can be in use before disconnecting. Does the phone give any kind of warning before it disconnects? My suggestion is even if the battery is well charged that might be the limit of the battery. If not the battery and you get a warning that the handset is about to disconnect you might try pressing and releasing the talk button to reset the handset timer if there is one before the 60 min. has expired. Doing this shouldn't disconnect your party.
Posted on Jan 09, 2014
5 Related Answers
Anonymous
  • 51 Answers
SOURCE: Transfering incoming phone calls Mod. Panasonic KX-T7730
do you mean call divert?
its possible.
we could do it.
Posted on Jan 17, 2008
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: Panasonic phone KX - T7630 - memory
Of course it's possible. Maybe the PROG softkey is a start. That an a manual.....
Carl
Posted on Aug 23, 2008
Anonymous
SOURCE: adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Posted on Nov 22, 2008
Anonymous
  • 15 Answers
SOURCE: Panasonic kx-tg1100
STEP1:
On the handset you want to discard go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
This will discard the registration of the handset to any base.
STEP2:
Using the handset you want to register go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
NOTE:If you do not get access to the BASE you are looking for (STEP 2) then you have to cancel the registration of the new handset to any base. Therefore, follow STEP1 for this handset as well and then follow STEP 2.
After you finish all the above, hold down the "PAGE" button for about 5 secs.
You are now done!!!
Good luck
Simos
Posted on Nov 23, 2008
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: panasonic kxtd816 with caller id card kxtd-193 problem kxt-7431
All Panasonic display phones, both analog and digital 7xxx series phones support CID. It requires 5 or 6 program adjustments as outlined in the manual. With luck, you may be able to just turn it on in 406, but your area code needs to be set if you have 7 digit local dialing, you need to tell the system if you want CID to adjust the clock daily, SMDR display, etc.
The 1232_PG lists all the steps. If you don't have a manual, you really need to get one. Post back and we'll see what we can do.
Carl
Posted on Dec 05, 2008
How can i pick up the call from my office phone when reception phone rings
Hello,Looks like you'll need to re-program your PBX unit. I would suggest looking up: 1.5.3.3 Outside (CO) Line Access 2.2.4 Operator/Manager Featuresin the Programming manual found here:
http://www.tongxun.com.cn/data/download/Feature_Guide.pdf
Hope this helps
Nov 27, 2012 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7636 I transfer calls from the office to the mobile but after about 10 minutes they get cut off. I don't think it's anything to do with the mobiles or the reception. Is there a...
There is and you found it. It's adjustable, depending on your system. In a TDA-30/50 it's system program 473 and the keyword search is either Extension - CO or Call Limit. If turned on, the default is 10 minutes...it's adjustable to 60 minutes.
Carl
Jul 06, 2011 | Panasonic KX-T7636-B Corded Phone
I currently use a Panasonic KX-T7431 at work and I wnat to either know does it have an answer machine function within the phone or can I buy one to add to it , we cusstenly do not have any faciity for...
Generally, a 7431 phone plugs into a Panasonic KX-TD phone system cabinet. The 1232 starts as an 8 line 16 phone cabinet, the 816 a 4x8, and the 308 a 3x8. To those systems, you can add a TVx Panasonic brand voice mail system, or even a plain old ansering machine. Both would need to be probrammed by someone familiar with ringing and intercept groups in system programming.
A quick call to your Panasonic installer or dealer would be the best, as it's beyond the scope of this forum to provide instructions.
Carl
Aug 17, 2010 | Panasonic KX-T7431 Corded Phone
Panasonic kxtd816 with caller id card kxtd-193 problem kxt-7431
Carl
Dec 05, 2008 | Panasonic KX-T7431 Corded Phone
KX-T7730, all the phones connect with operator ring at the same time when having an incoming phone
please i need your help,i use KX-T7730 in my office and of recent when incoming calls comes in all the phones in the office starts ringing and also i would like to know how i can lock and unlock the phone so as to prevent other users from accessing it.Thanks
Apr 10, 2008 | Panasonic KX-T7730 Corded Phone
Forwarding a call
Lift handset, dial 3 or 6 ( depending on model) - key outside line access code - key phone number (eg mobile)- key # - hang up
Dec 18, 2007 | Panasonic KX-T7730 Corded Phone
Expanding phone system
We have existing Ativa Model # D5772 & just purchased a 2nd model How do we connect the 2 systems?
Dec 12, 2007 | Panasonic KX-T7453 Corded Phone
How do ichange the time on Panasonic KX-T7431??
MUST BE DONE FROM EXT.101
1.leave handset in the cradle
2.Press "Program" button
3.Dial *#1234 (star pound 1 2 3 4)
4.Press Sp-phone button 3 times
5.enter the correct hour on the dial (2 digits)
6.press the button (in the lcd window to advance to minutes)
7.enter the correct minutes
8.press auto dial/store button
9.pick up hand set/ hang up hand set.
Oct 29, 2007 | Panasonic KX-T7456 Corded Phone
Lands Phones Logo
60 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
martin hogg
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
