The dryer stop working but still display the time and counts down as if it is working. Sensing button is on but it seem like there is no connection
SOURCE: whirlpool dryer,duet
Problem: Push On Button, Press to Start. Click. Sensing. No Tumbling.
Solution: Called repairperson. Replaced Thermal Fuse (Part 3390719) and also suggested having venting system checked (ours vents through attic). Charged $198.00. This did not appear to be a problem that a layperson could fix, although a very handy person might be able to do it.
1) sounds like that accudry sensor needs checking. If the accudry sensor (the back box with the two silver trips in it under the lint filter) does not sense wet garment it coul cause the dry to start and then cut off or not start at all. did you try using a cycle that does not sense the load you are dying. 2) the mother board of the dry may need chnaging depening on your dryer. if your dryer is like the cabrio, duet or the senseon dryer then it could be a motherboard problem.
SOURCE: Whirlpool Cabrio dryer won't start - the "sensing" light is on
where are the answers on those stupid site
SOURCE: Another Whirlpool Cabrio Sensing issue
Hi-- none of the solutions I've read here are working. Same problem, dryer not starting, it says "Sensing..." and then "Wet" and does nothing. It worked fine on the last load, except I noticed it read 11 minutes for a very, very long time (I think it got stuck). New load? "Sensing..." etc.
SOURCE: My Whirlpool Duet Dryer, 5 years old has the
From the service manual Sensing When the dryer is first turned on, the Sensing light glows until a wet item is detected. • In an Automatic Cycle, if a wet item has not been detected within 10 minutes, the Sensing light will turn off, and the dryer will shut down. • In a Manual Cycle, if a wet item is not detected after 10 minutes, the Wet light turns on, and the selected cycle continues. Since we are not getting an error code let's try turning off the power at the breaker panel for 5 minutes. See if this clears the issue. if this doesn't clear the sensing lite then email me and I will forward the service manual to you. It has a $25.00 value but I will trust you to not give it out to anyone.here is my email [email protected] In the meantime until I hear from you i will continue to read the manual. When you receive the manual you will need to perform the diagnostics test to determine what the issue is.
