Are you sure you bought lithium cells? In your camera you should use Ni-MH batteries. The SNB-2512 could be very expensive, but normal Ni-MH from any brand should work fine.
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is low, according to NiMH or alkaline batteries.
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera.
SOURCE: camera shutting off indicating low battery
I had the same problem, apparently if you're using a external memory card that can cause this problem...
I didn't know that but I contacted Samsung and got mine repaired.
They put a note in saying the power board was faulty in the camera.
Much, much better now. I can take pictures like I used to be able to!
SOURCE: Camera shows low Battery and goes off even if u insert a new one
are you using NiMh rechargeable batteries?
If yes, check that they are fully charged. If that doesn't do the trick, sounds like it might be a power circuit issue. Samsung is in Secaucus, NJ
or SamsungUSA on the web
SOURCE: Low Battery Light Even with Brand New Lithium Batteries
If indeed the batteries are brand new and without a doubt charged,
then you definitely have a hardware problem in the camera.
You're probably going to have to give it in to be serviced.
Hope I helped!
Tom
