Question about Lenovo ThinkPad R60 Notebook
How to turn on the wifi on Lenovo L430 - Lenovo ThinkPad R60 Notebook
Lenovo g450 wifi not working
hold fn key and then touch wifi key at the same time.should turn on.first of all check drivers are installed.if still no joy.wifi card could be faulty
Jan 22, 2015 | Lenovo Computers & Internet
What is the error L430
you need to include your printer's name. is this an error message on a printer's window? is it a message on the pc that the printer is connected to? if you google "error l430", you primarily discover that l430 is a model of lenovo thinkpad and not a printer.
go to ghe printer's manufacturer's website and enter a search for the particular model. it may offer a user guide and some support service. error codes with numbers are usually in a technician's manuals rather than user manuals, however. but you might try resetting the printer and those guidelines well may be in a downloaded manual. there might be troubleshooting software on that site which could assist. without knowing which printer it is, the problem could be anything from a paper jam or out of ink to a clogged nozzle or mechanical failure or because the printer is not plugged into the computer. yes, that happens too. try reposting and identifying the printer.
Jan 21, 2015 | Office Equipment & Supplies
Unlock scroll key for Lenova L430
Hi
This is a function key operation.
Fn+K: has the same function as the Scroll Lock key on a conventional keyboard.
The link below takes you to a page from which you cn download the full manual for future reference.
Laptops and netbooks ThinkPad Series laptops ThinkPad L430 Lenovo Support...
Cheers
Oct 31, 2014 | Lenovo ThinkPad L430 Laptop Computer
Lenovo T410s wifi adapter not found. How can i troubleshoot?
Please ensure that the correct drivers for the wifi adapter are installed. T410's can have different wifi makes, and installing the wrong one will make the wifi inoperative. Ensure you grab the drivers from the Lenovo support site.
May 23, 2014 | Lenovo IdeaPad Y430-3231U Notebook
My Lenovo z580 shows nothing when i tried to turn on my Wi-Fi by pressing Fn+F5. Any solution or alternative to turn on wifi?
Reinstall the WiFi driver:
Lenovo Support Drivers Software US
Alternatively, you can Enable/Disable WiFi by opening:
Control Panel>Network and Internet>Network and Sharing Center>Change Adapter Settings
You should see your WiFi connection listed. Right Click to Enable or Disable.
Oct 07, 2013 | Lenovo IdeaPad Z580
I think there is a sliding button to switch on wifi on my Lenovo 3000 N100 but it doesn't seem to be working.
Hi supriyamahta,
That's right, there's a physical wifi switch for your Lenovo 3000 N100. It's located on the front panel of your machine. It should be toggled on the right side if you wanted to turn it on. If it's not working you might need to turn on it's wifi soft switch. All you have to do is to press the Fn + F5 button. In any case and still you will be encountering the same issue that wifi switch can't be turned on I will ask you to contact Lenovo so they can give you proper recommendation on how the wifi switch can be replaced.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Computers & Internet
Wifi is not working...
you may wanna try to press Fn+F5 then wifi should pop up where in current status should be on..if it is asking for wireless radio to turn on check the wireless switch on the left side above of the ssd card..
if it is still not working try to uninstall and reinstall wifi driver in device manager
hope this helps
Apr 01, 2011 | Lenovo IdeaPad S10-3 Netbook
Cannot turn on wireless radio on Lenovo Idealpad
Press FN+F5 button together on the keyboard to have the settings for display pops up on the screen. Check if the radio button was turned on both for wireless and bluetooth connection. If the radio button was off, just click ON and that should set the wifi to turned on. Always make sure that the wifi switch was set to on as well.
If this didn't fix the problem, kindly reinstall the wifi adapter driver by downloading the driver from the manufacturer's website. after reinstallation kindly reboot the computer.
Please leave comments if you have any other questions.
Cheers~
Jun 19, 2010 | Lenovo IdeaPad Y510 Notebook
Lenovo T61 Wireless not connected
To turn on the wifi card. Make sure that the driver is install the press FN + F5.
Thanks for using Fixya.
Oct 14, 2009 | Lenovo ThinkPad T61 Notebook
Lenovo ThinkPad R60 Notebook Logo
328 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
