Question about The Nesco 4808-25PR Stainless Steel 18 Quart Porcelain Cookwell Roaster
TEMPERATURE DIAL DOES NOT WORK CORRECTLY - The Nesco 4808-25PR Stainless Steel 18 Quart Porcelain Cookwell Roaster
Gil Shultz
  • The Master
  • 3,388 Answers
More information please; what are you asking. You stated the temperature dial does not work correctly; There are a lot of things that can indicate. Try reading the manual.
The manual can be gotten at: http://us.wow.com/search?s_pt=aolsem&s_it=aolsem&s_chn=14&q=nesco%20oven%20roaster%20manual
Posted on Nov 27, 2014
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
Temperature indicator
You may have a problem with the coolant temperature sending unit and or the fuel level sending unit or an issue with the instrument cluster.
Apr 17, 2014 | Hyundai Excel Cars & Trucks
I have a Paragon 8145-20 D-Frost-O Matic installed in on my walk-in freezer. The ice is accumulated on the fins of the freezer. Now it run for 11 minutes then stop for 3.5 minutes. I think the stop time...
1) Copy following links:
http://waterheatertimer.org/images/8145-work-image.jpg
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
2) Typically the 8145-20 defrost cycle is time-initiated and starts when tripper pin located on outer part of dial passes the time-of-day point.
Defrost cycle terminates or ends when pressure or temperature switch activates. This is also called the cycle limit switch.
http://waterheatertimer.org/images/8145-20-wiring-600.jpg
3) So your situation sounds like the pressure or temperature switch is not working correctly.
4) The 8145 timer also has 'time termination' setting. This red tripper is located on inner part of dial.
Usually the 'time termination' is used as back-up system if the pressure or temperature switch fails so that defrost cycle will not continue melting everything in freezer.
5) To solve problem until pressure-temperature switch is replaced, you can disconnect wire on terminal X, and then set 'time termination' for correct length of time by experimenting.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 27, 2012 | Paragon 8145-20 Defrost Timer
Hotpoint ew81n cooker. Non working oven thermostat has been replaced. The cooker temperature is hotter than the dial reading. What can I adjust to make them the same?
Hi.
Unfortunately, the oven thermostat is non adjustable.
However, it is normal for oven temperatures to vary by + or - 10% of the setting.
This is acceptable, so to compensate, set the temp 10% less of the required temp setting.
Make sure you have the sensor fitted correctly inside the oven compartment
Make sure that the thermometer is accurate if you are checking the temperature with one.
Feb 23, 2011 | Hotpoint Ovens
How to set and align the hot/cold dial on a triton dela on a 7-0491-18743 shower so the temperature dial works correct
there should be a notch or maybe flat spot on the stem it fits on for align purposes.
Jan 31, 2011 | Home
The blower would not shut off, it kept blowing cold air. My repairman came and we saw the silver dial was in the completely upside down position (the 3 pointers were at the top). The pointers were set at...
The dial positioning does not really matter as this is a thermometer of sorts. It is a thermo controlled switch, upon reaching the desired temperature it turns on the blower and upon cool down it shuts off the blower. The dial positioning is not necessarily critical but with him turning it he could have damaged it meaning that instead of registering at say a set 150 degrees it may actually be more than 150 or less than 150 and it will work just the set temperature may be wrong. Confusing isn't it!!
Dec 25, 2010 | Honeywell L4064B2236 Fan/Limit Control...
I have a farberware convention turbo-oven model 460 serial number 2336445 I can only read the first two temperatures on the dial [150*- 250*] I am guessing that 350*- 450* is that correct ? , is that...
The top temperature is actually 475 (which is 550 in a regular oven). That's with the dial turned as far as it goes to the left. Don't know how you'll figure out the settings for the temperatures above 350, unless you measure the intervals below 350 and mark them off on the other side some way.
Here's a picture of the dial on my oven:
Oct 08, 2010 | Farberware T490C 1500 Watts Toaster Oven...
Dial not working correctly, set on low numbers water comes out at high pressure, set it on high numbers and the water pressure comes out on low pressure ???? why.... the item in question is a Triton Madrid...
It sounds like the numbers are for the temperature indication and the higher the temperature the more slowly the water runs because it takes longer to heat it.
Apr 16, 2010 | Home
Switch light goes on when pressed but goes off if not pressed
Switch light goes on when pressed but goes off if... OR iron does not heat at all even pressing the button to turn it on continually.
Don't understand which one question you are asking
But if there is no heat at all after switching it on, it needs to go to iron heaven but be sure to cut the plug of the end, Saftey reasons at the dump. BUT if lights are coming on the iron is working. the large dial on the water filler is temperature control. Turn this around to cotton or linen.
The light will come on and off while in use, it allows you to know that the iron has cooled and is going back to your select temperature( on the large dial)
Make sure that you use water in the iron as it will aid your ironing and make it quicker. Make sure that the iron temperature dial on the water filler is at the correct temperature for the item that you are ironing.
Hope this helps
Sep 17, 2009 | Black & Decker Steam Xpress AS250 Iron...
The Nesco 4808-25PR Stainless Steel 18 Quart Porcelain Cookwell Roaster Logo
268 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
