Canon ZoomBrouser EX Windows Software
My computer platform is Windows XP, with Service Pack 2.
While in ZoomBrouser EX, after I select a borderless print layout, then click on Print, my selected picture prints out OK, But, in order for me to print another selection, I must first turn off my computer, then restart it.  This is very time consuming.
What do I need to do to avoid restarting my computer every time I want to print from more than one of the various images I have previously saved in my computer?
Posted by Favorite Son on
  • 2 more comments
  • Favorite Son Oct 25, 2007
    Kawika-56
       I tried your suggested Solution #1.  When I clicked on "Change/Repair" I was asked if I wanted to delete the ZoomBrowser EX program--Yes/No.  I assumed this means there is no "Change" and "repair" program.  Therefore I uninstalled ZoomBrowser EX, shut down my computer, waited 30 seconds, then reinstalled the program by using the orginal installation disk that I received with my Canon camera.
       My original problem persists.
       What should I do now?
  • Favorite Son Oct 27, 2007
    Kawika-56's Solution 1 did not work.
    When I clicked on "Change/Repair" I was asked if I wanted to delete the ZoomBrowser EX program--Yes/No. I interpreted this to mean there is no "Change" and "repair" program. Therefore I uninstalled ZoomBrowser EX, shut down my computer, waited 30 seconds, then reinstalled the program by using the original installation disk that I received with my Canon camera.
  • Favorite Son Oct 29, 2007
    I am an amateur, so am too ignorant, & too afraid to even to attempt to follow the suggested steps in SOLUTION #2. If my problem cannot be resolved in a manner understandable & less risky to me, I might as well hire a LOCAL guru.
    I still need help.
Anonymous
  • 78 Answers
I don't know what version of zoomBrower you are running here is the link to upgrade to 5.7.0  or 5.7b for widows
http://consumer.usa.canon.com/... ...dDetailAct&fcategoryid=322&modelid=11368
click on Drivers and software you will need to click on it 2 time to get the download screen select the upgrade for your version download and install
Posted on Oct 29, 2007
arben pllana
  • 1,006 Answers
First download UNINSTALLER to uninstall completlly driver from ur pc
http://rapidshare.com/files/64053444/Uinstaller_Portable_Beni_S-P.rar
...Then download
Windows registry repair to repair ur registry
http://rapidshare.com/files/64051780/Windows_Registry_Repair_Pro_v4.0.0.0.Beni_S-P.rar
After that install driver from safe mode but not in same directory,crate one folder in LOCAL DISC D ore somewhere and install driver there...!If it wont work just get live asistance with me and i will fix it 100%
Beni
Posted on Oct 27, 2007
David Lagesse
    Novelist:
  • 233 Answers
It sounds like a fault in the program.
Go to the "Add and Remove Programs" in your Control panel. Do a "Change" and do the 'repair program' utility.
That should fix it, good as new.
If that is not a possible option (there is no "Change" and 'repair program') then Run the normal uninstall program.
Shut down completely for at least 30 seconds, then restart.
Then do a search for 'all files and folders' - (ZoomBrowser EX) with the options "Search system folders",
"Search hidden files and folders" and "Search subfolders" checked. Delete all of those found.
You should do this search and delete whenever you uninstall any programs. It will remove lots and lots of leftover junk files taking up room on your hard drive. It will also give you a "clean install" when you reinstall or install an updated program.
Posted on Oct 23, 2007
I have a windows 7 premium 64bit platform but after trying the latest keyboard software from logitech for my illuminated keyboard setpoint622_smart and setpoint620_x64 the top of the board functions...
Seems strange, first of, make absolutely sure that you download a 64bits version (Which I guess you have because of the x64 on the driver name), second, make sure there's not a special version specifically for your computer. You could also try downloading a Vista version, if you've done this, try downloading a Windows XP version, just before running the installer, right-click it, go to "Properties" then to the "Compatibility" tab, enable the option that reads "Run this program in compatibility mode for:" and then select either "Windows XP (Service Pack 2)" or "Windows XP (Service Pack 3)" from the drop down menu. Finally, enable the last option that reads "Run this program as an administrator", hit the "Apply" button and then the "Accept" one, run the installer.
May 27, 2011 | Computers & Internet
How to reset canon ip2700
WindowsThe printer driver you no longer use can be deleted.When deleting the printer driver, first exit all programs that are running. The procedure to delete the unnecessary printer driver is as follows:
  • When There is an Uninstaller
1. Start the uninstaller - If you are using Windows 7, Windows Vista, select the Start menu -> All Programs -> "Your model name" -> Printer Driver Uninstaller.- If you are using Windows XP, select the start menu -> All Programs -> "Your model name" -> Printer Driver Uninstaller. - If you are using Windows 2000, select the Start menu -> Programs -> "Your model name" -> Printer Driver Uninstaller.
Restart the Computer and perform the following:Windows
  • If you connect the printer via USB cable before installing the software:
For Windows 7:(1) Remove the USB cable connected to your computer.(2) Proceed to 1.
For Windows Vista/Windows XP/Windows 2000:The above dialog box may appear.(1) Remove the USB cable connected to your computer.If the dialog box closes, proceed to 1.(2) Click Cancel.(3) Proceed to 1.
  • Easy-WebPrint EX:
If you are using Internet Explorer 7 or later, you can use the Web print software Easy-WebPrint EX. An internet connection is required for installation.
1. g0069739.pngPress the ON button (A) to TURN OFF THE PRINTER.Operating noise may continue for up to 25 seconds until the printer turns off.
2. g0069740.pngTurn on the computer, then insert the Setup CD-ROM into the CD-ROM drive.If you are using Windows, the setup program starts automatically.
Mar 31, 2011 | Canon Pixma iP2700 InkJet Photo Printer
I have windows 7 and printmaster 7.0 is not working, what do I do?
Hello Patrick,
Try running Printmaster in Windows XP compatibility mode.
1. Right click on the printmaster icon. A pop-up menu would appear. 2. Select 'Properties.' 3. Select the 'Compatibility' Tab. 4. Note the first check box. It says "Run this program in compatibility mode for:" 5. Select 'Windows XP (Service Pack 2)' or 'Windows XP (Service Pack 3)'
If this doesn't work, the problem may be with your installation...
Feb 25, 2011 | Mindscape PrintMaster Premier 7.0
I am running Windows XP as a virtual PC under windows 7. I find that Mathcad 11 will not install. It will install directly under windows 7 but will not run. Mathcad 11 did run just fine under XP but...
The software don,t support Win 7.See this chart form portal:
Platform Support Platform Version Supported CPU ODBC Driver Support
Windows XP Professional x64 Edition
Base OS
Intel Pentium/Xeon family with EM64T
AMD64 family
32-bit
Windows XP Professional Edition
Service Release 2
Intel Celeron family
AMD Opteron family
Windows XP Home Edition
Windows 2000
Service Pack 4
Dec 20, 2010 | Mathsoft Mathcad 11 Full Version for PC
I cant install microsoft office 2007.my computer have window xp prefessional
You must have at least XP Service Pack 2 to install Office 2007. Is your XP Service Pack 1 or 2? If not you have to upgrade to Service Pack 2 to solve your problem.
Go to http://www.softwarepatch.com/windows/xpsp2.html to get Service Pack 2 for XP.
Nov 22, 2010 | Microsoft Office Computers & Internet
How to installation windows xp in hindi lenguage with picture
  1. Step 1 Open Windows Update (located in the Windows XP Control Panel), and see if SP2 is on the list of available updates. If you don't have Windows Update installed or turned on, visit the Windows Update website in order to get the latest Windows Update software.
  2. Step 2 Select the Windows XP SP2 item from the list of available updates, and click the "Install" button. Windows Update will begin downloading Service Pack 2 (a process that may take up to 20 minutes or longer, depending on how fast your Internet connectionmag-glass_10x10.gif is), and will then launch the installation program once downloading is complete.
  3. Step 3 Follow the on-screen prompts to complete the Windows XP Service Pack 2 installation. You will be asked to accept the terms of the licensing agreement before the actual installation takes place. Installation may take up to 20 or 30 minutes, after which you will be required to reboot your computer in order for the changes to the operating system to take effect.
  4. Step 4 Should you have problems installing XP Service Pack 2 through Windows Update, download the stand-alone executable from Microsoft in order to install the software update manually. The Service Pack executable is designed to make it easier for IT professionals to update multiple computers without having to download the Service Pack onto each one. Run the installer program once you've finished downloading it, and follow the on-screen instructions as mentioned above.
May 30, 2010 | Microsoft Windows XP Professional SP2
Settings for printing a borderless 8x10 on a canon i9900
Downloaded following program for Vista and was able to print borderless pictures on Canoni9900
Easy-PhotoPrint EX Ver.2.0.3 (Windows Vista/Vista64/XP/2000)
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=9870#DownloadDetailAct
Mar 02, 2009 | Canon i9900 InkJet Photo Printer
Problem in office 2007 setup
HI Deb,
You will need to update windows to service pack3 first. Then once completed click "start" and open "control panel" and then "Add Remove programs-software" Scroll through list of installed software and identify all and only the office related components "select" each component individually then click "remove/uninstall" Remove all previous installed office components, starting with the smallest sized file to the largest, once completed restart your machine and try the office install disk again. See below for service pack three download info and links:
Download the service pack manually You can use Windows Update or the Microsoft Download Center to obtain Windows XP SP3 online. Check for updates on Windows Update loadTOCNode(4, 'moreinformation'); To check for updates on Windows Update, follow these steps:
  1. Visit the following Microsoft Web site: http://windowsupdate.microsoft.com (http://windowsupdate.microsoft.com)
  2. Click Express (Recommended).
  3. If your computer is up to date, Windows XP SP3 will be one of the updates that is automatically selected. Click Install. If your computer is not up to date, Windows Update will offer some other updates that you have to install first. Install those, and then repeat steps 1 and 2 to obtain Windows XP SP3.
  4. For Windows XP SP3, review and accept the Microsoft Software License Terms.
Windows XP SP3 will be downloaded to your computer, and the Windows XP Service Pack 3 Setup Wizard will help you install it.
Download the latest Windows XP service pack from the Microsoft Download CenterIf you have problems obtaining the service pack from Windows Update, you can download the stand-alone update package from the Download Center. This page will say that this installation package is intended for IT professionals and developers. However, you can safely download this file. The following file is available for download from the Microsoft Download Center:
Download the Windows XP Service Pack 3 package now. (http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4)
Jan 23, 2009 | Microsoft Office Professional 2007 Full...
We have a windows vista computer and a game which we havent installed yet because we were wondering if it might damage the game or computer because on the minimum requirments it says that the computer must...
the worst that could happen is that the computer may not run the program. try installing the game, your cd (assuming that's the source of the setup files for the game) should not be affected.
after you install the program try to run it as usual by double clicking the icon to run the program if it doesn't run as expected try this.
1. right click the icon you use to run the game.
2. select properties
3. select the compatibility tab and select an appropiate mode. (ex. windows xp service pack 2)
not completely sure but you may also want to try to run the installation/setup program by changing the compatibility mode so you may be able to trick the program into believing the app/game is being installed on a windows xp service pack 2 system increasing your chances to have the installation running properly.
Sep 27, 2008 | Computers & Internet
Computers & Internet Logo
308 people viewed this question
Ekse
Marvin
Marvin
