Question about Avanquest Smart Business Pack
I bought a Smart Business Pack from Staples that did not do what I expected. I want to return it. oackage said 90 day return Follow user manual instructions. There were no instructiona in the package.
Last 6 digits of barcode910543
  • angel whitaker Jan 20, 2016
    I have the same problem. I'm still in the 90 day return window, but there is no instruction manual on how to follow the 90 day guarantee process for returning. Did you get an answer on how to go about this?
1 Related Answer
Anonymous
  • 6 Answers
SOURCE: I purchased the Smart Business
You will need to get in contact with Avanquest support. Their technical support is ran through SoftCity, so you will need to call them at (818)-665-3011. Tell them your problem, and provide them with your order number, and the representatives should be able to resend the code, or give you a new one.
Posted on Apr 04, 2011
I purchased the software los the box for the smart business pack. I need the activation dcode
contact the company and have your receipt handy they should be able to supply you with a code as you have proof of purchase of the pack
when you get it ( probably by e-mail) copy past it and print it out and stick it to the label of the disc for future installations
Aug 31, 2015 | Avanquest Smart Business Pack
It quit working after putting 10 staples--- spring will not return
Sounds like you have a damaged or bent staple stuck at the business end' of the machine.
Nov 21, 2013 | Powershot Tool Company Tools & Hardware -...
I bought a Powerfix Profi hand stapler from Aldi store but cannot get replacement staples. There is no support from their website
You can use about any replacement staples from a D.I.Y. store:
8mm staples or 12mm U-type staples or 10mm T-type nails
Nov 03, 2011 | Tools & Hardware - Others
SunSmart 15312 - timer has power and will turn lights on/off manually but will not turn on/off automatically after setting program.
Sun Smart is new GE timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
There is no repair for defective timer, except buy another at Home Depot and return defect in new package.
When I bought 15312 timer for testing, I found many packages at Home Depot were taped together as if people returned the timer. The large aluminum fin shows that timer is expected to get warm.
When testing the timer, the door stuck, and the timer seemed cheaply made. Intermatic brand timers are more robust at this time.
The instruction manual is not clearly written as could be, and timer requires a lot of button pushes for each setting.
Because the instruction manual is complex, requiring multiple button pushes for each setting, I suggest writing out the steps to make sure nothing is skipped over.
If lights turn on-off with override, then timer should be wired correctly.
Be sure to reset timer before programming.
Press setup button twice to begin programming.
Check programming for conflicts and overlaps that will cause timer not to function as expected.
For example selecting days of week. If program1 ON says turn on at 7:00 pm all days of week, and program1 OFF says off at 9:00 pm Tuesday.
Another point of confusion is Dawn-Dusk-Time. If you want timer to turn ON at 7:00, then select Time.
Sep 21, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I bought Nextar Q4-06 GPS from Khols last winter. Even though I don't use it a lot, I have problem turning it on. I plug it to my car for days to charge it incase it is out of electricity. Turned it...
I hope this helps you. If you just bought it less than 7 months ago. this is the route to go.
Nextar Repair/Replacement Procedure
Nextar wants to make sure our customers enjoy their purchase. If you have any problems with our product please check if our Support page can help you out first. If the product doesn't work, please follow the steps below. In order to serve you better, product registration must be completed to receive services. Click on Registration below this page and fill out the form.
-Package up the defective item and all parts included. Before you ship to us you must call Nextar for a repair code and be sure the item is within the warranty terms. If your item comes to us and is not within warranty terms it will be returned to you.
-The repair code helps keep track of your return; if one is not associated with the package, it will be returned to you. Customer Support/Technical Service can be reached at 1-888-849-0846 (Monday to Friday 8 a.m. to 5 p.m. PST. Closed on holidays.)
Warranty Period
Different products will have different warranty period. Customers can refer to the table below or product registration and warranty information at the bottom of the page.
GPS 1 Year MP3 / MP4 90 Days DVD Player 1 Year Digital Photo Frame ( below 5-inch/ Keychain) 90 Days Digital Photo Frame (5-inch or larger) 1 Year Stereo Speakers 90 Days Projector 1 Year Portable Media Player 1 Year Refurbished / Open Box 90 Days
US Customers
Nextar
1661 Fairplex Dr.
La Verne, CA 91750
Attn: (Repair code goes here.)
-Proof of purchase is required for all repairs/replacements. No Exceptions. Please be sure a copy of the receipt is forwarded to us in your shipment and the repair code is on the copy. Once Nextar receives the defective claim it will be examined and either repaired or replaced and then returned to you within 2-3 weeks under the Limited Warranty.
We appreciate your cooperation and business!
Jun 22, 2011 | Nextar Q4-06 Car GPS Receiver
I purchased the Smart Business Pack from Staples Business depot (canada) last year, and am currently trying to use it for the Web easy web designer. It's telling me that I can only use it 3 times without...
Apr 04, 2011 | Avanquest Smart Business Pack
My office has 2 Tekk NT 90 radios, but no user's manual or instructions for them. Need basic operation info so they can be used.
The Tekk NT90 is a basic walkie-talkie style radio. With a good battery they will operate a full business day on a charge. The radios should be charged overnight (or 8-12 hours) after the battery is depleted or nearly depleted. If using these in a business situation you can usually go a full 8-hr day on a charge. Battery packs have approx a 2 year life expectancy before needing replaced.
If you need more info, contact Tekk Inc at 800-521-8355.
Best regards.
Oct 18, 2010 | TEKK Radio Communications
I traveled with my Canon Lide 90 and the lock switch was engaged. When I returned to use it the following happened: The switch was unlocked; the USB connected to the computer and the scanning process...
The exact same thing happened to me this weekend to my SD450. I called Canon and they .... (The battery pack carries a separate 90-day limited warranty.) THIS WARRANTY DOES NOT .... The Lock Release Switch of my Canon SD550 came off. ..... So I returned the SD550 and for $68.00 more bought the Canon PowerShot S80. ...
www.digitalcamera-hq.com › Canon
Jul 16, 2010 | Canon CanoScan LiDE 90 Flatbed Scanner
How do I load staples into the Minolta Di 2010f copier?
Follow instruction on door. Push in on both sides of staple cart pull the top up install the new staple pack dont pull string on staple pack until its inside. (Staples on the floor:)) Don't throw away the plastic cart itself insure the arrows on the new staple pack match the direction on the old run or the staples will be upside down and not able to get out of the pack
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 17, 2009 | Minolta DI-2010F Copier
Misrepresented product?
No manufacturing process is flawless. These things happen. Return to staples for an exchange. Most managers will exchange ink even after the 14 days. If they dont, then buy new ones and recycle the nonworking ones for $3 on your rewards statement. I have seen people come back the same day after they bought a brand new HP ink cartrige beucase it does not work. Its not that they had the wrong cartridge, its just that it was a bad one.
Dec 07, 2007 | HP 56&57 Inkjet Cartridge Combo 3-pack...
Avanquest Smart Business Pack Logo
114 people viewed this question
Top Avanquest Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Sheldon Dedek
Bill Boyd
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
