Question about Electrolux Lux 7000 Bagged Canister Vacuum
Help me fix my LUX7000
On my Lux7000 the vacume says the bag is full and tuns off right away but the bage is new. If I don't have the hose on it will run but if it has even a little restriction it stops. The only way I have been able to bypass is to block the exost off.
  • 1 more comment
  • Anonymous Dec 02, 2007
    Thanks so much for your help!
  • giardinop Dec 09, 2007
    mine seems to go off way too early. I'm running thru bags like crazy...is it a scheme to sell bags ;) I'm still under warranty so I'll have it looked at. Unless there is a simple solution.
  • jmzak Dec 30, 2007
    We have the same problem with our Lux7000 but thanks to MICHGO, we've solved the problem but now have a new one....where are the directions MICHGO posted on the website to open up the vacuum? We are unable to figure out how the heck to open this thing!
Anonymous
  • 75 Answers
Turn the dial down to its least sensitive setting and try that. If not you can call my office at 570-326-1731
Posted on Jan 23, 2008
Anonymous
I have a lux7000 a question mark lights up and I changed the bag,filter and cleaned the hose out. Whats wronge with it?
Posted on Jan 02, 2009
Anonymous
Check to see that if you still have a warranty on it! I did and it didn't cast a thing! It was the flow valve...and I am so glad that I didn't get the vacume open after all!
Posted on Apr 29, 2008
Anonymous
    Problem Solver:
  • 15 Answers
IT'S THE CONTROL VALVE, IT'S LOCATED UNDER THE DIAL ON TOP OF THE MACHINE.
IT'S A CLEAR PLASTIC VALVE THAT SEVERAL CLEAR HOSES ATTACH TO. YOU CAN BUY ONE AT AN AERUS/ELECTROLUX DEALER. I'VE POSTED HOW TO OPEN UP THE VAC ELSE WHERE ON THIS SITE IF YOU CHOOSE TO DO IT YOURSELF.
GOOD LUCK!
Posted on Dec 02, 2007
  • Anonymous Apr 28, 2008
    THE FIRST THING YOU NEED TO DO IS GET A NEW CONTROL VALVE.GO TO YOUR LOCAL AERUS DEALER AND TALK TO THE REPAIR PERSON.BYPASS THE SALES STAFF,THERE VERY SLICK AND WONT BE VERY HELPFUL.AERUS MAY NOT SELL IT TO YOU BUT IT'S WORTH A TRY. CHECK E-BAY TOO.IT SHOULDN'T COST MORE THAN $20. IT LOOKS LIKE AN MINIATURE ARTIFICIAL HEART,IT'S CLEAR PLASTIC.
    PULL THE DIAL OFF. STAND THE VAC ON END OPEN THE DOOR.TAKE A SCREWDRIVER AND PLACE IT BETWEEN THE SIDE RUBBER BUMPER AND THE BOTTOM OF THE MACHINE AND SLIDE THE BUMPER UP PART WAY,BOTH SIDES. IF THAT HARD TO DO PEEL OFF THE BUMPER AND THE DO THE ABOVE WITH THE PLASTIC HOLDER YOU'LL SEE.
    PUT THE MACHINE BACK ON IT'S FEET THEN SLIDE THE BUMPERS OFF. IN ORDER TO GET THE TOP OFF REACH UNDERNEATH FROM THE LEFT SIDE AND PULL OFF THE CLEAR PLASTIC HOSE THAT LEADS TO THE TOP.
    NOW CAREFULLY LIFT THE TOP OFF AND LAY IT TO THE RIGHT OF THE MACHINE.
    NOW TAKE PICTURES OF THE UNDERSIDE OF THE TOP. REMOVE THE HOSES FROM THE CLEAR PLASTIC CONTROL VALVE.PULL THE VALVE STRAIGHT UP.IT'S HELD IN PLACE BY TWO SPIKES MOLDED ONTO THE TOP.THEY CAN BREAK OFF SO BE CAREFUL. POP THE NEW VALVE IN REATTACH THE HOSES EXCEPT THE ONE YOU FIRST REMOVED. LIFT THE TOP CLOSE ENOUGH TO REATTACH THE LAST HOSE AND PUT THE TOP BACK ON. MAKE SURE THE BACK PLATE IS IN PLACE ON IT'S SPIKES,TOP AND BOTTOM. THE TOP HAS TO BE ALIGNED CAREFULLY. NOW SLIDE THE BUMPERS ON PUT THE KNOB BACK IN PLACE PUT A BAG IN, THE HOSE ON THEN GO VACUUM SOMETHING!
What does the key light stand for on lux7000 canister vaccuum?
The light on the top of the 7000 that represents a "key" as you state it, is actually a "No Bag" light. That means to check the bag compartment for a bag. Replace if you do not see one. Close the door, push the start button, and voila....it will start. If it doesn't , make sure the bag top (cardboard) is flush inside. It may be missing the bag switch. Hope that helps!
Oct 11, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
Where do you hook up hose
Years ago I used to sell and demo kirbys up to the G-5 model,I believe you have to sit in front of your vacume,raise the wheels as high as they can go and on the logo face tun the crank one way,this loosens the belt and give a little tug and the roller sucking chamber will drop.Pull the chamber away.,now take your hose and stick it over the shaft and lock it down with the wing nut and then you can use all your vacume attachments.UNLESS YOUR TALKING - vacume bag hose- this is just a simple twist and click on the vacume exhaust chamber. Now if your hose is unhooked in your vacume bag it self,you will have to get a new bag attachment or get a repair man to look at it.
Jan 08, 2012 | Kirby G6 Bagged Upright Vacuum
Eletrolux lux7000 manu and how to retract the power cord?
For the user's/owner's manual, go to the below link, click on the arrow below where it says "Older Models", click on Lux 7000, click on "download". If you want a service manual, they are only available to Aerus Electrolux stores.
For retracting the cord, try tipping vacuum up on it's back end and gently pulling and releasing cord. This will often cause it to retract. If not, keep in mind that the canister portion of this vacuum has a 7 year warranty on it, so depending on when you purchased it, the cordwinder may still be covered. The warranty does not cover normal wear and tear, or abuse. There are other things that will void the warranty.
Nov 26, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Where can I buy a new control valve for my lux7000?
Some manufactures, like electrolux have to bring in parts from overseas, making lead times a real issue. I do understand your frustrations, as this is something I deal with every day. BUT there is hope... I am including a link to Electrolux's web site, and a dealer locater, try putting in your zip code, and possibly zip codes for cities that you wouldn't mind traveling to.
http://smallappliances.electroluxusa.com/node85.asp
I hope this helps.
Jan 22, 2009 | Electrolux Lux 7000 Bagged Canister Vacuum
Can't get my lux7000 to run
Make sure the bag is in place correctly. The question mark light indicates that there isn't a bag in the machine. There is a small button in the front of the bag housing that is depressed by the cardboard top of the bag. I think it is located in the bottom right hand of the bag housing if you are facing the front of the machine. Make sure the bag is depressing this actuator when the front of the machine is closed. If it is, it may be an internal problem with the switch. Good Luck!!
Jan 03, 2009 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux 2000 Mod# c151c
Turn the knob on top all the way to the right
Jul 04, 2008 | Electrolux UltraLux 2000 Bagged Canister...
No suction..says bag full
There is most likely an obstruction somewhere in the system that is not obvious to you. Please inspect all hoses. I have seen a sock in a vacuum line before, it caused these same symptoms.
Jan 05, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Same Shut Off Problem as Hamster71
The part that you call the particle size sensetivity adjuster is bad. There are 2 seals in the assembly, the lower seal is slipping out of place because the plastic lip which keeps it in place is broken. Split housings and replace part. This machine is alot of work to take appart and get back together correctly. Might want to bring to local vac shop. good luck.
Nov 15, 2007 | Vacuums
hey just thought you might like to know that I have been given an answear on the same problem log in to get the info. Now I just need to know how to open it without breaking it!
Oct 26, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Lux 7000 Bagged Canister Vacuum Logo
306 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Thomas F. Schneider
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
