The printer is perfectly calibrated and ready to print. However, the java application I am using is failing to communicate with the printer. I keep receiving this error: "javax.print.PrintException: Printer is not accepting job." I unsure how to resolve this issue.
SOURCE: Zebra Z4M continuously feeds paper and errors out.
It seems like you have a bad upper/lower media sensor or you need to adjust or clean it. If you remove your media and ribbon from the printer you will see two sensor's right behind the printhead. Printhead will need to be in the open position to see them. They should be emitting a red light. Clean and recalibrate. If that doesn't work it should the two sensors. They come in a kit. And just to be on the safe side you can call in to my technical support team to verify that is your problem. Its Free as long as parts that are needed are ordered thru us.
If you have any other questions please feel free to call.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 X240
AOL IM: RORYMRP
SOURCE: Zebra LP2824 Not Printing
I had the same problem and could not fix it but called Zebra headquarters and they gave me this solution and it works! It sounds crazy but it works. Turn off the printer on the switch on the side. press and hold the button on the front of the machine while you turn it on. The light will turn red then release the button the light around the button will then turn a solid greed then blink green. While it is blinking green press and hold the button again until it the light turns orange and then release the button. This apparently puts your printer into line mode or something but anyway it works!
SOURCE: Clear print job on Zebra printer
Simply press the PAUSE button then press CANCEL. If you have sent a batch of 500 labels, though, you will have to press CANCEL 500 times. I usually just turn the printer off, cancel the job in the printer driver status box, then wait for all of the error messages to pop up.
SOURCE: LP2844 printer stops after one page with out of paper error
Did you try to reload the labels. Pull the labels out and clean the paper path
SOURCE: We have a Zebra 105SL
The data light indicates that the printer is receiving data. Hold the cancel key for 10 seconds while powering on. This will print printer configuration. Use to troubleshoot. If the data or format is wrong it will not print as you send data. Make sure you are using the 105SL printer driver. To test the printer functionality you can go to www.teklynx.com and download a demo copy of labelveiw, select the 105SL printer and try to print a simple label. If you can print with labelveiw then it is not a printer problem. Double check your driver and label format.
Hi as you will see I have cut this from the manual its not very specific
I hope this is of some help
Ian
Description Recommended action
49.XXXX
PRINTER ERROR
To continue
turn off then on
None A critical firmware error has
occurred that caused the
processor on the formatter to
abort operation. This type of error
can be caused by invalid print
commands, corrupt data, or invalid
operations. In some cases,
electrical noise in the cable can
corrupt data during transmission
to the printer. Other causes
include poor quality parallel
cables, poor connections, or homegrown
applications. On rare
occasions, the formatter is at fault,
which is usually indicated by a
79 Service Error.
1. Press CANCEL JOB to clear the
print job from the printer
memory.
2. Turn the printer off and then
back on.
3. Try printing a job from a
different software application.
If the job prints, go back to
the first application and try
printing a different file. If the
message appears only with a
certain software application or
print job, contact the software
vendor for assistance.
4. If the message persists with
different software applications
and print jobs, disconnect all
cables to the printer that
connect it to the network or
PC.
5. Turn the printer off.
6. Remove all memory DIMMs
or third-party DIMMs from the
printer. (Do not remove the
firmware DIMM in slot J1.)
7. Remove all EIO devices from
the printer.
8. Turn the printer on.
9. If the error no longer exists,
install each DIMM and EIO
device one at a time, making
sure to turn the printer off and
back on as you install each
device.
10. Replace a DIMM or EIO
device if you determine that it
causes the error.
11. Remember to reconnect all
cables that connect the
printer to the network or
computer.
12. If the error persists, replace
the firmware DIMM.
13. Replace the formatter and
calibrate the printer. See
Calibrate now (HP Color
LaserJet 5500 models only).
