Insignia Kix MP3 Player Logo
A
Anonymous Posted on Oct 23, 2017
Charge how to get it to charge
I plugg my insignia into the computer to charge it and all i get is ok to disconnect how do i get it to charge ive tried everything i know to try and it doesnt help me ive unplugged it then plugged it back up ive turned it off then back on while its plugged in my computer ive tried to change the battery but cant figure out how to turn it on
1 Related Answer
Anonymous
  • Posted on May 17, 2009
SOURCE: my insignia wont turn on please help!!!!!
I always have to hold the button for at least ten seconds.
1helpful
My 4GB version is freezing my computer screen when hooked up
  • Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer’s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
  • Try resetting the device it’s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds.
1helpful
Computer monitor
If one of those 5 computers has a working monitor,
set the device-resolution to 800-by-600 and the refresh-rate to 60 Hz.
Then, disconnect the "working" monitor, and connect the "problem" monitor.
It should say "auto-adjust", and then it should continue to display that 800-by-600 image.
Try upping the device-resolution to 1024-by-768,
and see if the "problem" monitor will support that resolution.
Try upping the device-resolution to 1280-by-1024,
I want to download an album from my computer to my Insignia mp3. When I plug the player into my computer all I get is the charging screen. I want to get the album from media player.Jerry
When the player connects only with the charging display, there are 3 points that need to be checked:
Battery and cable connection
1. Connecting the player to the computer, the charging symbol should start loading; battery "green" or "partly green" indication. The player should respond with "OK to disconnect" = connection established correctly.
For proper charging and connection put the USB cable plug directly to the computer preferred at the back side: not through a hub or card reader.
MSC mode
2. The player is switched to MSC mode. MSC = Mass Storage Class. In this mode the device is seen as a flash drive also called removable disk, that can be accessed using Windows Explorer.
The Hold switch was in hold position on the top side, before connecting to the computer.
Disconnect the player and release the hold switch. Next the player should be in standard MTP mode. MTP = Media Transfer Protocol used for transferring files with media software.
MTP mode
3. The media software on the computer for transferring files is not installed or not working properly. Update or reinstall the media software.
Manual for Insignia NS-DV2G:
http://insigniaproducts.com/cms/documents/NS-DV2G%20UM%20EN_SP_FR.pdf
When this didn't help the firmware on the player needs to be reinstalled.
For firmware see the Drivers in the Support tab of the next link:
http://insigniaproducts.com/products/portable-audio/NS-DV2G.html
My insignia wont turn on please help!!!!!
When I plug my Insignia sport into my computer it tell me its ok
Trying Formating and Then Refreshing it. I had the same problem before and that worked.
My insignia sport 2gb video mp3 player does not turn on no more . :[
just plug it into the computer with the usb it came with so it can charge.
My ipod doesnt turn on and nothing works... it doesnt charge and when i plugg it to the computer nothing comes up on itunes so i cant even restore it or anything, ive tried everything... please help
hi,
1. Make sure the Hold switch is off
2. Make sure the battery is charged
3. Reset iPod
4. Let iPod's battery drain
5. Update iPod's software
6. Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
7. Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
8. Try connecting iPod to the built-in port of a different computer to see if that works.
IF all the above is checked and if ur ipod still remains same please take it to an apple store and check with them!..thank you!!..
Top Insignia Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
